Question about Siemens 24 in. SE64A630GB Built-In Dishwasher
Water pump works from the minute I press the main switch
Hi! from the minute i press the main switch on the water pump starts pumping water out (clearly audioable) i opened up the filter and i could feel the drift. and it does nothing else.
please help - wwhat should i do?
I may have had the same problem. At the end of a normal wash cycle the pump would stay on for hours or even days - I would have to power off, and then keepp trying to power on until it had eventually stopped. The pump operates even with the door open.
Problem is caused by a small float which senses the water level in the dishwasher, floating up and operating a microswitch, which turns on the pump to pump the water out. Obviously, if the dishwashe is filling up for some reason, you want the pump to operate even if the door is open. The float is in a small chamber - a very snug fit, with a hole in the bottom which is connected to the main pipework in the machine. There is another chamber next to the flot chamber which is also connected to the pipework. When the water level rises too high, water from this second chamber overflows into the flot chamber, raising the float and operating the pump. The water level then drops as the water is pumped out. The water level in the float chamber should also drop, but didn't on my dishwasher because the hole in the bottom was blocked (with old soap suds and grime I assume). Hence the pump just stays on. I assume in my case, the water flowed out very slowly, and eventually the pump stopped.
To fix it, removed the left hand side panel (2 screws on the front door lip. The back of the panel is just hooked on some raised bits of plastic). This exposes all the pipework, and the red float can be seen in it's chamber. I removed an extra couple of bits of plastic near the float chamber whilst I tried to work out what to do - but this may not be necessary. You will have to try for yourself. I couldn't get access to the hole to poke something in to unblock it, so I poured sink and drain cleaner into the flot chamber, topping up as it drained away, leaving it for approx. 15 mins. I think thick bleach would also work. Note: this cleaner won't be very good for any metal inside the dishwasher, so run 1 or 2 wash cycles to clean it out.
Maybe the dishwasher cleaner advertised on tv would have worked i.e. the stuff you put in the dishwasher on an emty cycle to clean out all the internals. I haven't used it, but it would be easier than taking the dishwasher to pieces.
Hope this helps
Posted on Mar 14, 2009
I solved the same problem where pump is going with door open, this was after reading johhny boy 1's advice ,
1, remove all trays inside,
2. clean filter area with sponge
3. poor jug of water into pump and if it is pumped away you have the same problem as me.
4 with pump filter/ mesh still out, pour a cup of house hold bleach into pump tray and top this up with a litre of cold water . turn pump on to empty.
5. repeat this 4 or five times
6 . pour a cup of bleach and this time top up with a kettle of hot water and pump away (turn machine on), the turn off.
7. leave for 5 mins then turn machine on and bang inside left wall with hand and when float drops the pump will stop.
8. flush washer with hot wash.
worked for me without having to strip down machine.
hope this helped , thanks johhny boy!
Posted on Apr 08, 2010
    Problem Solver:
  • 4 Answers
It's likely a problem in the controller. A repairman is your best option. If you're comfortable with electrical troubleshooting and appliance disassembly, locate the schematic and troubleshoot the problem yourself.
Good luck.
Posted on Apr 13, 2008
I called my technician with the same problem. He said he had a busy day, and suggested to do the following:
Tilt the dishwasher, and let all the water in the plinth pour out.
After doing so the machine started working again.
I had water coming in from the sink, because of a clogged pipe.
According to my technician, if you have water in the plinth, you might have a leak somewhere, so the non stop working pump is just a sympthom of the problem !!
Good luck !
Posted on May 27, 2010
Just bought the machine. Basically, the problem is that the steam wand goes of on its own (or as soon as I push the coffee button) and that I cannot turn the steam handle at all or do anything to stop...
Hi. Make sure all your buttons are off. (switches all facing the same direction). Then make sure the tap is turned off. Switch main power on. Then switch the coffee on. you should hear the pump start. usually loud at 1st, then it will get quiter as the water is pumped up through the group head. When water is pouring through the group head, switch off the coffee button. Now let it finish heating. If you can get to this stage, then everything is ok. If you cant get it to this stage then you have a problem with the machine. Most likely a themostat on the boiler. Darryn REPAIRER
Sep 22, 2011 | Rancilio Silvia Espresso Machine
Clean light flashing continuously. machine wont start.
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 02, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light is stuck on and dishwasher wont start
Hi
Daniel
Jul 18, 2011 | Kenmore Dishwashers
Clean light blinks all the time and we can't start dishwasher
Hi
Daniel
Jun 16, 2011 | Kenmore Dishwashers
Mode light stuck on clean. will not start by pushing the start button.
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
Hope this helps... Please post back for further assistance.
Daniel
Mar 25, 2011 | Kenmore 1348 Builtin Dishwasher
Clean light is blinking but machine wont start
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Feb 27, 2011 | KitchenAid 24 in. KUDP02CR Built-in...
I have a Kenmore 8575287 The clean button is blinking and when I push start it just blinks and does not start.
Hi
Jan 27, 2011 | Kenmore Dishwashers
Same problem
Power it off at the mains for 60 mins and then rety. If it still does the same then call in a repair man as it is most likely thatthe main controller board is faulty and needs replacing.
Sep 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
GU1200 will not drain. Seems to have stopped mid-cycle. Pressed can cancel button , now it just blinks.
Does this model have a rotary control? If it does switch the unit off at the mains and move the controller to the end position and then switch back on. If the pump is working it should then start the pump to drain the machine.
If it doesn't have a rotary control just switch off and leave for a few minutes. When you switch back on it should then pump the water out.
If the pump isn't working you should be able to open the door with the power off. Dishwashers don't fill up with water so water won't leak out. Clean the filters and look for something blocking the outlet.
Aug 29, 2009 | Whirlpool Dishwashers
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
Siemens 24 in. SE64A630GB Built-In Dishwasher Logo
1,034 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
