Question about Hyundai ImageQuest L70S 17" LCD Monitor
Monitor Speaker How to enable monitor speakers
  • 55 Answers
Make sure the speaker input from the computer is plugged into the back.
Make sure the volume control is turned up and not muted on the front.
Posted on Mar 15, 2008
How do I get volume on my Dell 2414H Monitor?
I believe this monitor does not have a built-in speaker. If you have the optional hang-on speaker, it must connect to the laptop's speaker/headphone port (speaker's green connector cable/plug). You cannot use the external speaker and the headphone at the same time unless you are using a Y connector cable.
This monitor has a VGA and a DVI-D ports for video input. Neither supports sound.
I hope this helps. Dell 24 Monitor P2414H
Oct 29, 2015 | Dell Computers & Internet
Speaker in/speaker out not working
Are you feeding the monitor via an HDMI connection? HDMI carries digital audio as well as digital video signals. If using DVI or VGA to connect it to your PC, there is no audio being fed to the monitor, so nothing can come out, unless you have a separate audio cable running to the monitor as well from the computer :o)
Nov 11, 2013 | Dell ST2420L 24 inch LCD Monitor
How do I turn on the Acer AL1717 speakers?
the internal speakers, RTM it tells you how.
you plug them in to the PC, audio part conn.
then unmute the audio.
then up the volume.
also RTM the monitor OSD may have speaker enable , selection.
that is it.
Sep 26, 2013 | Acer 17" AL1717 Flat Panel Color LCD...
I have no audio out. Buy my S243HLBMII monitor have a speaker and an audio input. audio input is only enable while I connect the lcd with vga cable. I want to disable the audio in and want to make it audio...
Hi lucasthehack,
I would like to help regarding your concern about the Audio issue you are experiencing with your LCD monitor using HDMI.
Since you are using HDMI you really do not need to look for an audio out to get sounds out of your LCD monitor.
- On your screen you will see a speaker Icon wherethe time is, right click on the speaker Icon then select Playback Devices.
- In the Playback Device Window you will see HDMI on the top of the list right click on it and click set as default, this will give you aduio out from the HDMI connection.
Restart you system with the HDMI conencted to the LCD monitor this should make the changes we made work using HDMI video and audio on your LCD monitor.
Thank you for choosing Fixya,
avf110686
Dec 21, 2010 | Acer S243HLbmii Widescreen LCD Monitor 24...
Hi, I have ViewSonic VX2235wm-5 22"
It appear the monitor has been connected to another system unit than the default. disconnect the entire systems and reconnect altogether, restart the computer to allow the unit to recognise the new monitor. should diplay possible soluiton, else follow the instrcutions below
1.locate the control panel where the options of systems setting is displyed.
2. a click should dispaly a list among which is device speaker options
3. the computer speaker could be updated by clicking to install drivers or codes acquirable from the network.
alternately
1. click on the hardware icons located after locating and clicking into control panel.
2. on the list of add delete hardware provides the option to attempt to delete the speaker codes
3. a delete of the speaker drivers on system restart would prompt the user to update the speakers. A click on the prompt should acquire the necessary installation kit patches from an internet connection if any.
Dec 06, 2010 | ViewSonic VX2235WM Monitor
Dell XPS M1210 laptop was set next to a speaker and now the bottom half of the screen is grey
It's due to the magnetic field interferences from the speaker. At the first place, you shouldn't keep it near the speakers.
Always keep speakers far away from the Monitor.Now turn off the monitor and turn it on again,hope it solve the problem. You may even need to restart the system.
Moving magnetic fields (such as from an electric motor) can cause flickering when near a CRT screen. A static magnetic field, such as from your computer's speakers, can cause color shifts or incorrect colors in the area near the magnet. This color shift is caused by parts of the screen becoming magnetized. Occasionally the color shift will remain after you remove the source of magnetism. To help reduce or eliminate the color shift, you can use the degaussing option on most monitors. Most newer monitors automatically degauss when you turn them on, while older monitors might require you do to it manually. Most monitors have a button or menu option that enables you to degauss it manually. Degaussing a monitor will de-magnetize the inside of the monitor, removing the color shift. Unfortunately, if the monitor is exposed to the source of magnetism for too long, degaussing will not be able to clear it up, requiring you to repair or replace the monitor.
Feb 08, 2010 | Dell InspironTM XPS M1210 Notebook
No sound on computer
check your sound cables speaker power button and speaker icon on computer is it enabled some dell pc have sound option in biose which needs to be enabled
Jul 22, 2009 | ViewSonic VA721 17" LCD Monitor
Can't get sound through speakers/headphones
You need to connect the speaker wire coming from the monitor to your PS3 if you want the sound to come out of the monitor speaker. Normally, you need an adapter for this.
Mar 15, 2009 | Computers & Internet
No sound from speakers in VLCDS23719-1W
Yes, is the speaker wire connected to your pc?
Jan 08, 2009 | ViewSonic VG700b 17" LCD Monitor
Monitor audio hook-up
You should need a mini jack audio cable. One end plugs into the speaker port of your sound card in the back of the computer (usually marked green). The other end should plug into the audio input of the monitor.
Oct 06, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
Hyundai ImageQuest L70S 17" LCD Monitor Logo
238 people viewed this question
Top Hyundai Computers & Internet Experts
Tom Stevenson
Level 1 Expert
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
