Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Wma 31 module connections x10 1 and 2 what colour wire for 1 and 2
  • 4 Answers
Posted on Apr 20, 2008
  • 105 Answers
No idea
Posted on Mar 15, 2008
Check engine code 31 for a 94 laberon
The 31 code is about the evap system purge solenoid circuit having an electrical problem (open or shorted). I doubt that explains the problem. dash. If you can get it to an Autozone parts store they will often do the readout for free.
Possible Causes Bad connection or wiring - Check the wiring and connections between the logic module and the solenoid. Clean and regrease any corroded connectors with dielectric grease and repair any shorts.
Bad solenoid - The solenoid is located in the right, front fender next to one to three other solenoids. See the Understanding Solenoids page for information about how to test and repair solenoids.
Diagnostic Method Trigger Parameters - Near 0V or near 12V not detected when the solenoid is turned on or off, respectively
Results If Component Fails Fault code 31 is stored.
Aug 11, 2010 | 1994 Chrysler LeBaron
I need to know what colour wires connect to the centre plug in the Convenience Unit of my 2002 VW passat 1.9tdi 100 bhp. The part number is 1C0959799A ( 013 ).
HI.
Can you especificate whish connector.
A/C module, Radio. Air bag module...
I have information for that car.
Thank you.
Jul 17, 2008 | Volkswagen Passat Cars & Trucks
1996 FORD EXPLORER , MISS FIRE ON CYL # 2, 1ST REPLACED PLUGS AND WIRES, THEN THE COIL PACK AND LAST THE FUEL INJECTOR BUT PROBLEM STILL THERE, ANY HELP WOULD BE GREAT
OK,
Have you tried the following:
Ignition Control Module (ICM) REMOVAL & INSTALLATION NOTE: Only the EEC-IV ignition systems use an external ICM. EEC-V systems have incorperated the ICM into the Power Control Module (PCM).
  1. Disconnect the negative battery cable.
  2. Detach the wiring harness connector(s) from the ICM.
  3. Remove the mounting bolts, then remove the ICM. To install:
  4. Position the ICM onto the inner fender apron and install the mounting bolts. Tighten the bolts to 22–31 inch lbs (2.5–3.5 Nm).
  5. Attach the wiring harness connector(s) to the ICM.
  6. Connect the negative battery cable. Fig. 1: Ignition control module and mounting location on the 2.3L, 2.5L engine 89682g32.gif
    Fig. 2: Ignition control module used on all EEC-IV systems except the 2.3L engine 89682g33.gif
    Fig. 3: Ignition control module mounting on all EEC-IV systems except the 2.3L engine 89682g34.gif
Jul 11, 2010 | 1996 Ford Explorer
Hotpoint WMA 9P Door locked indicator light flashing will not allow machine to run
If the door lock indicator light is flashing it means the door is not closed .......or the machine thinks it's not closed. Give the door an extra push just in case, the areas to check would be the switch, the wiring connections and the tracks on the module. If you find any tracks on the module have blown also check the motor for lose or broken wires because the module does not blow for no reason.
Mar 19, 2010 | Hotpoint Washing Machines
I would like to know what coloured wires connect to where in a Furuno Gps navigator 31
Thyere are onlyb two wires red and black red is power black is return and the green earth should not be earthed anywhere on the case. If you need the manual contact me admin@nettiser.com.au
Please nrate my help++++Thanks for using FIXYA
dont rate if you have more questions as it locks me out, use email
Oct 17, 2009 | Furuno GP31 GPS Receiver
My HP photosmart 2710 will not turn on. There is 31 volts going into it??
Option 1
If you have a blinking light try changing cart.
Option 2
If the unit is blackout change the power supply. Here are the specs
Power specifications
* Power consumption: 75 W maximum
* Input voltage: AC 100 to 240 volts - 2 A 50-60Hz, grounded
* Output voltage: DC 31 volts === 2420 mA
Sep 16, 2009 | Computers & Internet
Looking for parts
can i ask wer you from ? so i know wer i send. if i found 1
tnx
Feb 20, 2009 | GE 31GT720 31" TV
Looking for manual for ''nec n-3480'' TV, missing power cord
Colour code Standard wire colours for flexible cable
Such as Extension cords, power (line) cords and lamp cords World Region, country
or other entity(ies) Live Neutral Protective earth/ground EU, Australia & South Africa (IEC 60446) brown blue green & yellow Australia & New Zealand (AS/NZS 3000:2000 3.8.1) red black green/yellow United States and Canada black (brass) white (silver) green (green) Standard wire colours for fixed cable
(In or behind the wall wiring cables) Region Live Neutral Protective earth/ground EU (IEC 60446) including UK from 31 March 2004 brown blue green & yellow Australia and South Africa red black green & yellow (core is usually bare and should be sleeved at terminations) United States and Canada black, red, blue(brass) white (silver) green (green)
or bare copper wire Note: the colours in this table represent the most common and preferred standard colours for single phase wiring however others may be in use, especially in older installations.
Nov 19, 2008 | Televison & Video
Need to remove the motor to change the brushes {hotpoint wma 31} have undone 2 bolts and removed wires but cant get the motor off.
i find these are rather stiff fixing. if all bolts are off, prize off gently with a screwdriver or similiar
Aug 07, 2008 | Hotpoint Washing Machines
PCB connections
follow the wires and find out where they go to then come and will take it from there, on my connection chart I can only see x10 x1 x5 x9 x2 and x4
Jun 21, 2007 | Hotpoint WMA31 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
