Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint WMA31 Washer pcb connections x10 1 and 2 ?
  • 105 Answers
No idea
Posted on Mar 15, 2008
SOURCE:
Wheres the filter on my hotpoint
Hi maizi42,
Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 11, 2011 | Hotpoint WMA31 Front Load Washer
My Hotpoint WMA31 will not drain - the smell is
check for blockage under cap bottom of washing machine
May 26, 2010 | Hotpoint WMA31 Front Load Washer
Door lock flashes doesnt work or start up
The flashing door lock light is indicating that the door is not closed proerly.
This can be caused by a weak or broken spring in the door handle.
Another reason for this to happen, is a faulty control board at the top of the washer, a blown track will cause this.
This in turn, is usally caused by a fault on the motor.
Hope this helps.
Jan 20, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint will start a wash then after about 5- 10 mins just stops?
could be motor brushes are worn if not spinning also...Quite simple to fit
Nov 17, 2009 | Hotpoint WMA31 Front Load Washer
Front panel connections for Hotpoint WMA 46 washer
red/red = x2 black/blue = x11 black/black = x9, hope this fixes for you
Nov 17, 2008 | Hotpoint WMA46 Front Load Washer
Filter
take off rear bottom panel.
you will see a large diameter pipe going from bottom of machine to pump. take off this pipe at the machine end - careful, lots of water may come out.
filter is located inside this pipe. remove and clean
Aug 31, 2008 | Hotpoint WMA31 Front Load Washer
Dont understand what the programs do
my hotpoint aquarius wf540 lights keep flashing
Mar 01, 2008 | Hotpoint WMA31 Front Load Washer
PCB connections
follow the wires and find out where they go to then come and will take it from there, on my connection chart I can only see x10 x1 x5 x9 x2 and x4
Jun 21, 2007 | Hotpoint WMA31 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
70 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
