Question about Brother MFC 210C All-In-One InkJet Printer
Can not get my printer to print from the computer
  • 832 Answers
Unfurtunately you didnt tell us what pc system you run: Is it XP, Win2k or Vista?
The latter one wont be able to connect to your pc.
For the mfc 210c are only drivers for xp and win 2k, 98se avaiable.
You need another (newer) mfc (mfc240 or 235) if you run vista.
Anyway, if you run xp, download the aggrssive usb driver remover from the brother homepage and delete the drivers installed.
After a restart of the pc do have the mfc DISconnect from usb port (which must be one of the pc: NO hub!). Insert install disc and wait until pc software demands the connection to mfc. Connect now to pc usb. Let the software finish the installation. This should work for xp and win 2k/98se.
Posted on Mar 15, 2008
I have a cannon ir3300i printer is not taken print..computer says out of paper printing..but paper is available in printing..how to resolve this query mail id internetstation2012@gmail.com
try turning off both devices - start you computer first, then start your printer and see if that fixes your issue. if not try again this time leaving out the plug that connects the computer to the printer and then when the computer is turned on turn on the printer then plug it into the computer
Aug 08, 2012 | Canon (6981A002AA) for imagerunner 2200,...
Help! Our Dell Inspiron 1521 laptop (service tag# 28D58F1) stopped printing. It was printing through our wireless network to our main computer with printer attached with no problems and then one day we...
There are several things to look for, but here are the first things to check:
  1. Is the printer plugged in and turned on?
  2. Can you print a test page from the main computer to the printer? If not, check what is in the queue to print on the main computer. Delete (Cancel) any print jobs in there that are not printing.
  3. Is the printer on the main computer marked as shared, if not, mark the printer as shared.
  4. Look at the print queue on the Inspiron laptop, if there are jobs stuck in there, delete (cancel) any stuck print jobs from the laptop and attempt to print a test page from it's printer properties by right-clicking on its icon in the control panel and clicking Print Test Page.
  5. If none of the above has revealed the problem...
    1. Remove the printer from the laptop by right clicking on its icon and choosing to remove the printer.
    2. Click on Add Printer and attempt to add the printer back to the laptop by following the instructions that come up. If the printer is not located, make sure your wireless network is running and that you are able to connect wirelessly with both the main computer and the laptop.
      1. Make sure that you are on the same Workgroup or HomeGroup
        (right click on Computer (or My Computer, or This PC) in your file explorer and choose properties to see your Workgroup or Homegroup information) in any case, both computers must be on the same network).
Oct 18, 2017 | Dell Computers & Internet
Trying to print a picture from my dell computer. when i hit print on the computer printer does not print. what button do i push on the printer itself. when i go to view/print it just says to insert memory...
With the printer power on, unplug and then plug in the printer from/to the computer. This should force the printer to be reinstalled.
Check the printer status.
Click START>Control Panel>Devices and Printers>click on your printer. check the status for any error messages. On the printer status, delete all pending jobs. Once the printer status display shows that all pending jobs have been deleted, retry printing.
Let me know if printing is reestablished. Thanks.
Mar 15, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Printer is on but will not print. Brother HL-2140 laser printer. The print log status reads = Error - Sent to printer.
Hello ,
First, please make sure there is no error message displayed on the LCD screen of the printer
Now we will check the status of your printer in the printers menu in the control panel.
The printer’s status should be set to “ready”
If the printer is “paused” simply clear the print queue, right click on the printer and select “resume printing”.
If the printer says “offline”, follow these steps.
  1. Clear the printer queue
  2. Shut down the computer
  3. Unplug the USB cable from your computer and your printer
  4. Unplug the power cable from the printer and wait 15 seconds
  5. Plug the USB cable back into the printer and the computer.
  6. Plug the printer’s power cable back in.
  7. Turn your computer back on.
Your printer status should be back to ready now and you are able to print.
Thanks,
Pat
Mar 29, 2010 | Brother HL 2140 Laser Printer
Can,t print document from computer to a brother 3420c mfc, computer says it is online and ready and the default printer, when i saf print and the prother dialog window comes up i say print and the document...
Hi, Billy.
1. Remove your printer from Printers and Faxes
2. Disconnect the printer cable.
3. Restart your computer
4. Reconnect the printer cable.
5. Your computer should see the printer and install the driver.
Hope this helps.
Sep 26, 2009 | Brother DCP-7030 Digital All-in-One Laser...
Switching from copy to print from computer
If you look carefully at the printer you'll note that there is no button for "Print" and the reason for this is that all the other functions are for using the printer as if it wasn't connected, nor needed a computer.
All your printing functions that DO use a computer require you to interact with the printer via the computer.
In short, to use the printer from the computer you'll need to make sure you've installed the correct drivers (see your installation CD or the Canon website) and then plug the printer in using a USB cable connection to your computer. If the computer recognises the printer you'll then be able to print.
In a nutshell if your printer is connected and drivers installed properly it doesn't matter what your printer has selected on the printers own control panel, you just print :)
Hope that helps.
Feb 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Printer not responding message when printing from the computer
I had the same problem and it was print spooler on computer.
Check that.
Dec 20, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Cannot get my printer to respond..when I trouble shoot it says printing paused, I click on resume printing and it still doesn't print... I unplug my printer and turn off my computer and once I restart my...
1. Click on START, CONTROL PANEL, PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE).
2. Right click your printer, and select PROPERTIES. (If your printer is not listed, click on VIEW INSTALLED PRINTERS first).
3. Select the ADVANCED tab.
4. Select PRINT DIRECTLY TO THE PRINTER.
5. Click on APPLY (if applicable), then OK.
6. Restart your computer.
7. Try printing now.
Aug 22, 2008 | Lexmark Office Equipment & Supplies
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
Docments
Every printer has a unique print driver on computer, and each and every printer uses a different one, so there goes it cant be my computer. The way to tell if it is a printer or computer problem on your machine is to Turn off, unplug from computer, ensure your printer has paper, power it on, wait for ready/online lamp, then press the "go" button 5 times super FAST. Status page should print if it does, then your problem is in fact the computer or the print driver not installed correctly on your computer, as I suspect may be the case.
Post back once you have verified if you have a printer or a computer problem.
Jan 08, 2008 | Brother HL-2040 Laser Printer
Brother MFC 210C All-In-One InkJet Printer Logo
95 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
