Washing machine Hoover 550 M Problem: Wont spin dry
  • 1 more comment
  • deanstorey Mar 15, 2008
    Yes the water pumps out
  • deanstorey Mar 16, 2008
    The switch is OK and the machine works fine for all other parts of the cycle. After it drains the water it doesn't start to spin. Is there a water level switch controlling when it should start to spin?
    I checked through the connections on the motor and brake release solenoid and found the strip connector slightly loose under the motor. After I reconnected this I tested the macine and it functioned correctly.
    Thanks for all your help,
    Dean.
  • 105 Answers
Does the water pump out
Posted on Mar 15, 2008
  • 1 more comment
  • william mikkelson Mar 16, 2008
    the hoover washer has a lid switch that is probably faulty or needs adjustment
    the machine thinks that the lid is open or tripped out so check that for fault
    ok i am not shure on that
    to check remove air tube off p/switch if you hear a click you now know there is no pressure on p/switch try and see if spins if it does then p/sw is no good
    but i think maybe the timer is faulty or the brake motor is not disengaging transmission but if hat happened the adjitator would go around and around
    one other thing on your washer that you may find that is the fault
    if it has a power module after the timer that will be the most likely cause of problem as the module switches the power to the motor so replace that
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: hoover washing machine not spin drying
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Hoover 2305L goes through all cycles well.does not spin fast enough to dry clothes.
how old is the 7 kg washing machine
should be direct drive to the drum not a belt drive
the motor could be wearing out
are you over loading
May 11, 2016 | Hoover Washing Machines
Hoover 750L top loader washing machine
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Goodluck,
Dont forget to rate me as Fixya..
Jan 30, 2008 | Hoover Nextra HNF 3167 Top Load Washer
Washing machine wont spin on quick wash
my samsung washing machine is not performing operations of washing, drying, drain
Feb 26, 2013 | Hoover Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Hoover 600MD wont spin dry
it seems that the motor problem you should replace it
Apr 17, 2010 | Washing Machines
I have a Hoover 550 MB Top Loader washing machine . The cycle won't move from wash to spin . it doesn;t progress out of wash cycle , it stays there forever .
Will the unit spin if you manually turn the timer dial to spin? If so, remove power, remove the clock motor from the timer, and inspect the clock and mating timer gearing for debris or damaged gear teeth. At the worst, replace the timer. You may be able to scrape or file the damaged teeth so that the timer will progress.
Oct 19, 2009 | Hoover HTC243 Top Load Washer
Wash cycle,spin dry, water level
I WOULD CHECK FOR A PLUGGED AIR PRESSURE HOSE OR THE PRESSURE SWITCH ITSELF.
Jan 26, 2009 | Hoover Washing Machines
Hoover 2305 washine machine wont spin
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
213 people viewed this question
Top Washing Machines Experts
