Question about Sony UP DR100 Thermal Photo Printer
Won't print but says "Ready"
I have the Sony UPDR100 plugged into my laptop with XP and it says "ready" on the printer and when I got to Adobe Photoshop and tell it to print on 4x6 and select the Sony as the printer to send it to then it asks me to name my file, i do and it saves a new file in my folder and my little printer pops up at the bottom of my screen for 2 seconds and disaprears and no photos is printed.
i have plugged the SCSI into the laptop, plugged the printer into my power source, then boot the printer then boot my computer and still have no luck.
Thanks
  • johnphotog Feb 26, 2009
    looking for solution to updr problem....all hooked up and printer is recognized but wont print....file sits in queu with printing error status.  any help???  please..
  • Justproof May 11, 2010
    What is the connection to the laptop? Are you using an SCSI to USB adapter?
    Most laptops will not have direct 50pin SCSI
  • 3 Answers
When using a sony up-dr100 and photoshop, you don't go to 'print' you use 'export'
Posted on Dec 02, 2009
Hi, try downloading the driver from the web go onto their web site, sometime the computer doesnt recognise the printer if you havnt downloaded a driver you should have the disc with the unit but as i said before download from the web ,,had to do this for my mac so should work let me know.
Posted on May 17, 2008
Hi
I have the same problem - how do I get it to print it says READY and its connected to my CPU via a SCSI card 50 pin NOW WHAT???? Do I need to install something else - do I need to use a specific program????
Posted on May 15, 2008
Keeps saying printer is "offline", but still
Contact the printer customer service, they may need to install an updated driver (especially if the printer is a Lexmark).
Aug 24, 2011 | Apple MacBook Pro MB991LL/A 13.3-Inch...
Have window xp, have adobe 8 when bring adobe 8 on line an alert says adobe 9 is ready says click here, don't know what to do.i have worked on computer 1wk.
Hi, Your adobe software needs to be updated. Yes, you can. This is a good thing. Just have your ant-virus ready and active. Good luck.
Jun 22, 2011 | Adobe Computers & Internet
Hp laserjet 4 does not print.
Just get another printer cable. That should be the issue since the printer, you said, does self test successfully.
Mar 26, 2010 | HP LaserJet 4 plus Printer
Laptop running vista will not print wirelessly
check the cable connections, unplug replug the cable.......then turn it on
Sep 09, 2009 | Epson Stylus Multifunction Inkjet Printer/...
DLINK DP-300U. Desktop shows printer offline, Laptop prints OK.
First thing.. plug printer directly into PC.. does it work? .. if so its is a port setting. If now it is the device config on PC
If Port Setting Issues.. are you going through any other devices on the network or is you firewall blocking the IP.
If device Config issue check to see it is setup up as an IP Port not a normal local port
Jul 15, 2009 | D-Link DP 300U (DP-300U) Print Server
Printer not printing
Uninstall everything. Reboot. Unplug the printer. Install the software. Reboot. When everyting is up. Plug in the printer. Have the driver disc ready, install the printer. Reboot, go to settings, printers and see if the printer is listed. If it is, make it the default printer.Good luck
Dec 20, 2008 | Computers & Internet
Printer womt print Adobe pdf file
Hi , Have you checked with -
1. uninstalling and re-instlling the Adobe application once more?
2.the spooler - opn run on your computer and type down "net stop spooler"- let the command window close - then again pen ru and type down " net start spooler " and let the DOS / command window open and close again. Try taking the print with the printer in the ready status.
3. usbcable detection
Step 2 and 3 will not be most effective if the other applications are printing fine.
Try uninstalling and re-installing the Adobe application.
Or else you have to contact the Adobe vendor for further issues. It could also conflict if you have older version of IE in your computer.Becaus Adobe 8.0 is the latest version that might conflict with the older version of IE
Apr 08, 2008 | HP Officejet 4215v All-in-One Printer
Wont print says its ready
Remove the USB cable from laptop, reboot the laptop. Turn off the printer and turn it back on. Once you are in windows, plug the USB cable back in. Sometimes the machine will lose it's connection. By doing the above steps will renew the connection. ope that helps.
Feb 27, 2008 | Office Equipment & Supplies
Back door closed
I did not get any error message but the 6940 printer would not print. Instead "Ready" the printer said "door open". When I deleted printer and plugged the usb cable back in the XP machine found the new hardware, said "Ready" and could print.
Dec 22, 2007 | HP Deskjet 6940 InkJet Printer
Sony UP DR100 Thermal Photo Printer Logo
354 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
