My computer is not booting it just shows (a disk erorr occur,to restart press.....)
  • Anonymous Jul 26, 2008
    will not boot up
  • puchie721 Jul 26, 2008
    will not bootup shows disk error
  • 88 Answers
Before trying to format try booting from your xp cd-rom. Enter the recovery console command prompt before setup starts proper and type 'fixmbr' and follow the instructions, then type 'fixboot' and follow the instructions again. Type 'exit', reboot without your installation cd in the drive and hope for the best.
In my experience these types of problems usually herald the impending death of your hard drive so use this fix only as a means to get your system up and running long enough to backup your important data.
Hope this helps,
erch.
Posted on Mar 15, 2008
    Problem Solver:
  • 10 Answers
Your system files is corrupt and much worse the mbr of your hard drive is damaged. try to reformat it and if problem persists, change your hard drive
Disk read error occurred, press ctrl+alt+del to restart, but it just takes me . ... press ctrl alt del to restart" problem, HOW TO SOLVE
Have you checked your bios to see what the system is configured to boot from first? Make sure your hard drive is the first boot device in the list.
Oct 28, 2013 | eMachines D620 Laptop
I have a disk error how do i fix it?
Could be the HDD or even just the boot sector itself. Basically, it's not able to read the Operating System Boot...or it got damaged somehow. If you have a disc for the exact version that is on the system, you may be able to fix it through the Advanced Options using the command prompt. (bootrec.exe /fixboot /fixmbr /scanos /rebuildbcd)
Oct 11, 2017 | Acer Aspire L100 PC Desktop
I have dell inspiron laptop, suddenly a problem occured I quot that :windows faild to start a recent software or hardware change might be the cause to fix the problem : 1-insert your windows...
Shut your computer all the way down. As soon as you turn it on, start hitting F8 about 3-4 times, that will take you to an advanced options menu. Select "Last known good configuration" and that should work
Mar 08, 2011 | Computers & Internet
My laptop is not startting i have a black screen that shows A DISK ERROR OCCURRED PRESS CTRL+ALT+DEL.. HOW CAN I FIX IT? i already try re -started i does not work.
You will have to start in safe mode so follow instrucitons below
To start the computer in safe mode 1.
You should print these instructions before continuing. They will not be available after you shut your computer down in step 2.
2.
Click Start and then click Shut Down.
3.
In the drop-down list of the Shut Down Windows dialog box, click Restart, and then click OK.
4.
As your computer restarts but before Windows launches, press F8.
On a computer that is configured for booting to multiple operating systems, you can press F8 when the boot menu appears.
5.
Use the arrow keys to highlight the appropriate safe mode option, and then press ENTER.
6.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
Chris Thrash
B52Computers
Jan 10, 2011 | Toshiba Satellite Pro L300 Notebook
Wont boot up says a disk read error occurred. press ctrl alt del to restart. i do this and the same message comes up
your operating system files is corrupt, that's why your computer is showing you that message.Your computer cannot but except the it is repaired.
To repair your windows, you will need the Cd that came with your computer, that's what you will be needing in other to repair your system.
Also, you can still boot your system by booting in safe mode. To boot in safe mode, restart your computer and immediately, keep pressing "F8" on your keyboard, a black screen will come up and you will see a booting option, scroll to safe mode and press enter.
Once your system boots up in safe mode, you can restart your system and the problem might be solved.
Take care.
Jun 01, 2010 | Toshiba Satellite A135-S2386 Notebook
A disk read error occured press ctrl+alt+del to restart...how to fix it?
This is not a good error but there are two things you can try.
1. Physically remove the hard drive from your computer then reseat/reconnect it. This will ensure it is connected securely. 2. Physically remove the hard drive, attach it to another computer (either internally or with a USB adapter) and run a CHKDSK. Once completed, put the drive back in your computer and boot it up.
There is a slim chance this will fix your issue, but honestly you probably have a dead drive. I hope you backed up.
Jan 21, 2010 | Microsoft Computers & Internet
When i cut on my labtop i cannot log on and it says something about a safe mode how can i fix this
Fir that when you power up the computer press continue F8 key then enter in safe mode.
Then go to start menu -> run
Type in run "chkdsk /r"
then press "y"
then restart the computer then it checkign disk and recover erorrs on diskm so wait for it after 100% completed it restart then you can login in winxp.
Aug 23, 2009 | Computers & Internet
When try to boot up, get disk read error Have Compaq desktop wit Maxtor 20G Quiet 5400 when i turn on my laptop i get "a disk error has occurred. press ctrl+alt+del to restart". i press that but nothing...
try to hit F8  or F10 and get into the BIOS of your system. Once you do that,see if it shows you your hard disk.
Even before that, remove all CDs / DVDs that are in the CD drive, USB Drives, that are in the computer and try booting it again.
Feb 17, 2009 | Compaq Computers & Internet
Computers & Internet Logo
131 people viewed this question
Alun Cox
David Payne
David Payne
