Question about Sony KP-61XBR48 61" Rear Projection Television
In response I do have the manual but I do not even know were to start. In another post you told someone to check transsistor T603 and Resistor R672. Do you think that is a good start for me and could you tell me what board they are on to find them. And is this usually an expensive problem to fix. I hope I don't have to spend too much but I don't want to scrap the TV either.
  • Sony Master
  • 8,617 Answers
Those are on the power supply board. Usually its a minor part that is causing the set to shutdown when you repair it at component level. Circuit board replacement is where you can find it getting expensive. just take your time and famillarise yourself with the manual and take one of the start up voltages at a time and verify that they are correct. If not then back up on that circuit checking the components outlined in the schematics that feed that component. You will find it. just be careful around the higher voltages. go slow and be safe with it.
Posted on Mar 14, 2008
Turn on my Sony FD Trinitron WEGA KV-32HS510 32" TV, you hear a click, and then it blinks 3 times pauses and repeats.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. This is the fault with 3 blinks. If you wish to get more, check the site linked here.http://electronicshelponline.blogspot.com/ Pull up previous posts, either by brand search, or view it in Mosaic / Timeslide / Flipcard option.
Aug 18, 2013 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Light blinks three times but dont turns on
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
It may be made up of a few faults but the power supply is a good place to start.
Hope this helps
Dec 21, 2010 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Getting over voltage protections 3 blink replace board and still nothing
Check T603,and R672,check all connections,swollen or leaking capacitors,burent resistors,fuse.hope this helps you some.
Mar 01, 2010 | Sony KV-29LS60 29" TV
Model number d52w20 power button flashes 3 times then nothing happens
this is a problem in the power supply check T603 and R672.good luck
Mar 01, 2010 | RCA Televison & Video
Kdf 50e 2000 goes off and red light blinks 3 times
Sounds like there a problem in the power supply circuit,Unplug the unit,and take the back off,with a ohm meter,check T603,and R672. Also check all solder joints for cold joints,bad connections,...hope this helps..
Feb 21, 2010 | Sony Televison & Video
Is the t603 and r672 part of the tv or the actual circuit breaker
Three blinks - B over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
DOES THIS ABOVE issue have anything to do with Cooling FAN?
I cannot hear the cooling fan come on when first turned on like
before THANKS
May 05, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KP46WT520 blinks three times
They are on the main power supply board. Yes if you can solder and are careful around the high voltage items such as T60s you should be able to do the repairs easily. I would recomend a service manual however. If you would like a link to get the service manual and parts let me know
Mar 16, 2008 | Televison & Video
Sony bravia 50" rear projection hd 3lcd tv
3 blinks in sony sets means B+ over current protection shutdown. Problem in power supply Check Transistor T603 And Resistor R672. Hope this helps let me know if you need any further assistance.
Jan 07, 2008 | Televison & Video
Sony
# blinks means B+ over voltage protection is shutting your tv down. Problem in your power supply. ChecK transsistor T603 and Resistor R672. What model do you have and I can help diagnose it in more detail for you. Let me know
Televison & Video Logo
64 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
