Re: How do I add players/ controlers to wii 4x4 circuit?
Press the button on the wii remote with a picture of a home and then press remote settings and then press reconnect and then press 1 and 2 alternatly on the remotes u want to connect
If it is a one player game the wii disconnects other controllers to save battery. Some games say 2 player but in the fine print you learn that it is only online (with other wiis)
You said when if the game starts the controller goes off.try holding the sync button on the wii console for 15-20 seconds then resync all controllers.If it doesn't work try this:Start the donkey kong game then press the home button then go to the wii remote settings it has an icon of a remote then after you enter it find the reconnect then press 1-2 simultaneously to select who is the first player.If it doesn't work try resynchronizing it as the first controller.Hope this helps.
the controls are VERY sensitive for this game.
But for the "circual driveng no matter what" is more like a problem with the wheel itself rather than the game.
I suggest returning the wheel and buying a new one or simply not using it and playing with just the Wii-mote itself.
does the controller work? if not then open the battery case and press the red button and then open the SD card slot area and press that red button and wait and it should eventually connect. hope this helps!
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide,
that explains step by step to fix the problem without any technical
knowledge. I hope this guide will solve your problem. It also gives
information on fixing many Wii Related Problems, so its a kind of Wii
Problems Reference Fix Guide.
