Question about Refrigerators
GE Ref model GSC23LSRD SS
The water exterior water source is so weak. I already replaced the filter twice, what else could be the problem?
  • Gary Davd
    Gary Davd May 11, 2010
    clogged water inlet valve where your water supply comes into the refrig oryour storage tank in the back wall of the refriger. is freezeing up
SOURCE:
Master_Tech
  • 770 Answers
SOURCE: GE Ref #ESS25LSRCE SS
are you sure it is not a GSS or a PSS model i have the manual on that post your email and i will send it to you
Posted on Mar 15, 2008
  • 172 Answers
SOURCE: GE Profile water filter housing leaks
Hi there is a grommet you can replace.
#WR02X10678 it is about $7.00 It can help seal the plug sometimes. Ge does want you to buy the whole filter assembly it is number
#WR17X11618 $51.50 . You may also consider putting a new filter in. It seals better than the plug it is number
#gwf $42.95. I dont know why they dont sell a o-ring kit. I guess they just dont make much money on o-rings. I hope this will help you. Have a nice day.
Michael Anderson
Anderson Appliance Repair
(865)945-3808
Posted on Feb 17, 2009
  • 3 Answers
SOURCE: GSH25JSRF SS Issue with water/ice delivery
I had the same problem as do thousands of people with this same fridge. The mother board is bad and needs to be replaced. It is easy to do yourself and the part costs less than a service call.: Unplug the cord from the wall, remove the panel from the back of the fridge (it is about the size of a small shoe box lid) You will see the mother board (ice, water, light, and compressor control unit). It is an electronic circuit board. There are about 5 or so plugs going into the board. Remove the plugs and the retaining screws and search Ebay for the part#WR55x10552 GE Power Control Board. I found one for $74, popped it in, and everything works better than new!
Posted on Mar 21, 2009
SOURCE: I replaced the water filter for my GE GSH25JSTA SS
I have had the same problem with the same model several times in the past. It also happens to me within a few days of replacing the water filter.
In my case, I believe the water line in the freezer door has become frozen. I usually let the freezer thaw for a couple of hours, and my water works again.
I have had constant problems with this model. I would recommend trying to sell your fridge now while it's still running, before the real headaches begin (mine has died 2x in the past six months, and I have not even had it for 2.5 years yet). No more GE's in my house.
Posted on Jul 20, 2009
aasc
  • 1606 Answers
SOURCE: RE: GE model #gsh25jsrf ss. The water does not
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Posted on Nov 01, 2009
Water dispenser stopped giving water. how do I get water to start coming back out?
have you tried cleaning the filter dispense or replacing it and/or trouble shoot your own refrigerator and then enter your model number
Dec 27, 2014 | GE Refrigerators
Tube leaking connected to water filter
General Electric refrigerator model number PSS26NSTB SS is not cooling and the fan motor stop
Jun 16, 2012 | General Electric GSS22JET Side by Side...
Hi, We have a ge refrigerator gsh25sgpa-ss. Water is leaking down the back of the inside of the freezer. We have replaced the filter and the water valve, any thoughts?
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 11, 2011 | GE Profile PSW26P Stainless Steel Side by...
Replaced my GE double wide refrigerator SMARTWATER FILTER #GWF With a which is supposed to be better. Yet, the water stream has cut down to half. Do I need the adapter collar for this newer model? ...
I have exactly the same problem. Replaced my GWF filter with the "new improved" MWF filter and the same thing happened. Tried replacing the filter not once, but twice - same low water flow. If you install the bypass plug the water flow is normal, so don't bother checking for water restrictions, bad hoses, tanks etc.. My refridgerator is a GE Profile 26 cubic foot purchased in 2004. I'm afraid these MWF filters don't work well in older models.
Oct 07, 2010 | GE Replacement SmartWater Filter for GE...
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Profile side by side refrigerator,model #GSC23LSRC SS
Have you tried a new GE filter? Use only GE brand. You can purchase a bypass plug from GE parts 800-626-2002
Jun 23, 2008 | GE DBSR453EBWW Electric Dryer
Mar 10, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
295 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
