Question about GE Profile PFIC1N Bottom Freezer French Door Refrigerator
Oven door no longer closes
After cleaning our GE oven (~10 yrs old), we realized we could no longer close the door. We could raise the door 3/4 the way up and but then it just stops.
I slid the oven door off the hinges and pulled the hinges out. They looked fine - no sign of any breakage/damage.
Can someone tell me how I might be able to repair this?
Thanks,
Jeff
Ottawa, Ontario, Canada
    President:
  • GE Master
  • 2,651 Answers
Sounds as if the hinges are no longer closing properly,its the only thing gonna stop door from closing, unless you can physically see something protruding from the door that would stop it. no t totally unheard of for the hinges to fail, especially after a self clean cycle
Posted on Mar 15, 2008
Is there something that is safe for me to spray/apply that will help loosen a door switch that sticks on a GE Advantium 120 Oven?
No, I would replace the switch. See this page.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 10, 2017 | GE Microwave Ovens
Display shows door not closed for self cleaning when door is closed
think it means lock door . there might be a sliding lever between the cooktop and oven door slide it to the right .
Feb 20, 2015 | GE JKP20 Electric Single Oven
Oven door won't close
if you look around under the handle or under the top of the stove on the front there should be thin lever. This lever is designed to lock the oven door closed tightly when you are activating the self cleaning oven feature. It is likely that someone accidentally lock the lever while the door to the oven was open. Simply find that locking lever return it to the unlocked position and your door should shut fine.
Dec 26, 2013 | Ovens
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
I have an 1950s' O'Keefe & Merritt Gas Stove that has oven doors that will not completely close. Can you help or locate a manual? Thanks
if the springs are not broken , the hinges are bent down ( droping the door for 60 yrs). Its tricky to bend back the hinges back. Springs and parts are no longer avaliable but you may be able to match someting close for a spring if you have the old one.
Oct 30, 2009 | Ovens
Ge profile range door wont close
was the door removed during delivery? Hinges not being fully seated can cause this. also check to see if the lock is striking the door liner, it should line up with a slot in the inner surface of the door and not touch anything unless the oven is in self-clean
Sep 01, 2009 | GE Kitchen Ranges
How to self clean
Depending on the condition of the oven, it could take up to 4 hours.
A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
Here is a link for your stove:
GE JTP18 Manual
Directions are on page 23.
Dec 13, 2008 | GE Profile JTP18 Electric Single Oven
Microwave is not working
One of the door switches needs to be replace.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Oct 30, 2008 | GE JVM1440 Microwave Oven
Gas Odor and Oven Heating
The gas valve may be failing. The 'whooshing sound' you hear may be the gas valve closing too slowly when the oven cycles off or the cavity is filling with gas and igniting when the oven cycles on. The gas you smell may be an indication that the valve is not closing completely. This can be potentially dangerous if the oven fills with gas then ignites. I would not operate the stove any longer and shut off the gas to the stove.
Jun 26, 2008 | GE Spectra JGBP35 Gas Kitchen Range
Ge double oven
I believe this is because it takes a while for your oven to cool down (the cleaning cycle uses a very high temperature to burn up the grease and food). The timer is how long it takes before it will be cool, at which time the oven will unlock.
Mar 17, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
GE Profile PFIC1N Bottom Freezer French Door Refrigerator Logo
124 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
