Question about Vacuums
Carpet Beater for Central Vac
I have a Hoover central vacuum with a carpet beater brush. One of the wires entering the carpet beater was frayed and eventually broke. I took the carpet beater apart cut off the broken wire, bared some new wire and re-connected the wires to their proper places. The carpet beater works on another Hoover system but does not work on the original. Took the handle apart. There is the plug, the switch and what looks like a circuit board to which wires are attached. they go to terminals that connect to the circular part of the end of the hose. The vacuum works but the carpet beater does not. Is it possible that one of these three items got shorted and needs to be replaced?
  • Bicycleman Mar 18, 2008
    I cannot see a spot for a fuse. The power wire for the carpet beater motor is permanently fixed into the plastic head that goes into the wall vacuum outlet. The other end of the wire goes into the female receptacle in the handle. I have had the handle apart and there is not a fuse in there. Thinking that it may have blown a main fuse when the wires shorted, I verified that the wall socket is functioning properly.
  • Anonymous Mar 25, 2014
    There is a frayed wire on the floor unit with the beater brush which appears to have a short circuit.
    President:
  • 1,673 Answers
Some of these types of hoses, if there is a male plug on the end that goes into the wall outlet, could be that one side of it is fused and will have to be replaced. When something happens like a short or a bad brush roll stall, this fuse will open up. If you supplied the model number I may habe been able to look it up and see. But if the hose end cuff comes off, then you can check it with an ohm meter to see if one side is open or not.
Posted on Mar 15, 2008
  • Lauren Junge
    Lauren Junge Mar 18, 2008
    If it has a fuse, it is an inline one, you won't see it. The plug inside the cuff may have it. It is the male plug that when you put the hose into the wall outlet, it makes a connection for the power head also.
SOURCE:
Where is the beater brush on a hoover max extract dual v
It does not have a beater bar. Under the front nozzle assembly is the brush block assembly which has 5 Or 6 rotating brushes which help to disperse the water and agitate the carpet.
Feb 16, 2018 | Hoover Vacuums
Beater brush will not turn even with belt intact
is there any loose pieces of carpet or twine wrapped around central bar.
Dec 28, 2015 | Hoover Self-Propelled WindTunnel Bagless...
If belt is stretched do i have to replace it
If the brush is not turning when on carpet, then yes. The beater brush will turn if the belt is touching it, so looknig at it when the brush is not hitting the carpet is not a way to see if the belt still functions. There should be a window where you can see the brush turning. If the brush does not turn while on carpet, replace the belt.
Nov 24, 2012 | Hoover Tempo Widepath Upright Vacuum -...
Beater brush won't spin when on carpet
You need to change the belt. When it does that it means it is worn. You can get replacement belts for it here:
Central Vacuum Belts
or here is
Broan Central Vacuum Belts
Nov 04, 2009 | Broan-NuTone CV350 Performance Bagged...
Beater brush will not rotate
If you have not had this unit in for any previous service, and you are tilting it back to engage the brush with the swich on carpet mode, then I would likely suspect the switch assembly in the upper handle. The new switch and harness can be replaced but you will also need the switch knob as well. Otherwise you can get the entire upper handle. This unit has a history of the lower cable wiring harness to go bad (not an easy fix).you can tell if you tilt the vac in carpet mode and wiggle the exposed cable at the bottom rear of the vac, if it starts and stops the it is bad.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 12, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Bought a new sweeper and brush ( beater bar ) does not turn. The large belt is fine and turns. The small thin belt is also fine but does not turn the brush. It is either the wrong belt or is there...
Jim, To put tension on the brush, tilt machine forward when upright, move carpet selector knob to carpet. then turn vac on. Brush will only spin when vac is tilted back to operate. brush stops when upright and on to use hand tools so the er is no danger to carpet or persons with moving roller.
Sep 29, 2009 | Hoover U6630-900 WindTunnel Bagless...
Need to replace belt on beater brush
If you press on either side of the raised top light cover it will come off. Then you will be able to see the light bulb and two screw heads. Remove the two screws and the top cover of the power brush will lift off and you will be able to access the belt. You can find this belt at www.vacbelts.com.
Jul 01, 2009 | Vacuums
Beater bar on singer central vac stops beating
try cleaning the ends of the brush roller. thread gets caught in there and jams it
Mar 07, 2009 | Singer Vacuums
Hoover 5470-900 no longer contacts carpet with beater brush
your floor adjustment spring is broken there is a plastic slider and clip if it is broken the height adj will not work you should get a new vacuum because this repair can cost as much as a new vac.also this is a common problem with the hoover brand I would get a sebo or an oreck they have a great warrentty and you will more than likly never buy a other vac.
Jan 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Dark marks on carpet after using hoover
these dark marks are burn marks from the beater bar itself. most walmart, kmart, and target shelf vacuums from hoover, dyson, and any cheeper vacuum has a hard bristle system. I've noticed even on the high end hoovers as well that they do the same thing. the best way to save your carpets is to see if there is a replacement beater bar that can be substituted for your vacuum. i dont know what style of beater bar that particular one is but check with your local vacuum repair center to see if they have something with softer brushes you can use insted otherwise i would recommend a new vacuum with softer bristles. usually something that is half as stiff as what is already on yur unit. you culd also try lifting the hight setting as a temporary solution.
Sep 06, 2008 | Hoover U5450-900 Windtunnel Supreme Bagged...
Vacuums Logo
173 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
