Question about Car Audio & Video
Crossfire amp 2ch, right side
The right side of my amp barely plays but when i take the negative lead off and hook it up bridged it sounds fine ,so that tells me that the negative lead on the right side isnt working write . what the hell ?
    Sergeant:
  • 300 Answers
Possibly an internal issue in the amp (i.e. broken solder joint on the circuit board). Also, check your RCA preout connections, too.
Posted on Mar 14, 2008
I have the Sony explode 1200 2/1 channel amp and 2 comp series lighting audio 10s 8ohm 900 watt max best way to hook up for loudest bass
You will have to wire subs together for a 4 ohm load. Then bridge amp (1 channel). Look on amp speaker outs to see what leads to use to bridge. Run positive and negative to one speaker then use a jumper wire from that positive and negative to the next speakers positive and negative
Sep 28, 2016 | Sony Car Audio & Video
How do I wire two subs up for the full 850 rms on a kac-9102d amp
  • Wire up two 4 Ohm subs in parallel (bridged) or one 2 Ohm sub.
  • You will take both of your subs positive leads and run them to the left positive (white connector on the amp) and both of your subs negative leads and run them both to the right negative (gray and black connector on the amp). That's max RMS right there. Pay attention to the Ohm rating of your subs as this does play a factor. What I explained is how to bridge two 4 Ohm subs. 8 Ohm is a little different but car subs rarely are 8 Ohm.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 27, 2011 | Kenwood KAC-9102D Car Audio Amplifier
It was laying on the workbench in my kids stole the fusesWhat size fuses go in a koiiler model 9696 1000watt Max amp? To bridge this 4ch to 2 on the high input side. do you have to tie the input side??...
NO dont tie the inputs. Inputs stay just as they are. Outputs are where the bridging happens.
You amp specs are:
XM-9696 C/W 4 CHANNEL POWER CHROME/WHITE AMPLIFIER
MAX OUTPUT POWER (2 OHM): 200W X 4 = 800W
POWER OUTPUT: 90W X 4 @2 OHM (360W) LESS THAN 0.5% THD
60W X 4 @4 OHM (240W) LESS THAN 0.3% THD
BRIDGED 180W X 2CH @4 OHM
So lets take 800 watts and divide by 13Volts DC = 61.54 Amps
So if there are 2 fuses start with 30 amp. To play it safe you could use 25 amps and if they blow try a 30. Now if the 30 blows you may need to take
another look at your wiring. I think 30 will be fine though.
Apr 02, 2011 | Car Audio & Video
I have everything hooked up right and system was playing fine. then the blue power button started flashing and subwoofer wont hit. the orange thermal light is also on. how can i fix it?
If your subs are dual voice coil, they will be tricky if you're not familiar with them. If you wire them in series ( a black and red together) and bridging them on the amp, you might be overloading the amp if it is not capable to handle it ( 1 ohm stable). Instead of bridging, try parallel series on the amp. A positive and negative will be wired together. The other postive will go to the positive of channel 1 and negative to the negative of chanel 2.
Or wire the speaker in parallel ( black with black- red with red) and you can then either bridge them on the amp or on their own channel
Jan 28, 2011 | Car Audio & Video
Ive got a 5channel zeus z7oo & im hooking up
if i were you i would put the switch to 4ch and the run one sub from ch1-2 bridged and then ch3-4 bridged. I would have to bet this amp is stable only to 4 ohms bridged with so many channels
Mar 19, 2010 | Hifonics Zeus Z700 Car Audio Amplifier
Loss of sound to passangers side speakers
?s amp ?cap r using?brigd 2ch 4ch hook w/ fused sep. mainly chk grd! amp on carpet over heats. vent it!
Mar 22, 2009 | Car Audio & Video
Improper function
try hooking up your subwoofers in series. then connecting them bridged to the amplifier. as follows: positive from sub#1 into positive of amplifier left channel.. negative sub#1 into positive sub#2. negative sub#2 into negative amplifier right channel. turn the gain down as this will sound pretty loud.
Jul 13, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
How to
First of all, make sure your amp is bridgeable. There are a few ways to bridge subs. series: hook one wire from the negative on the left amp output (or whichever is labeled on amp for bridged)to left sub negative. left sub positive to right sub negative, then right sub positive to the amp positive output.(like a big loop through both speakers) parallel: both speakers get their own set of wires, both negatives go to the bridge negative terminal, and both positives go to the positive bridge terminal. Series-parallel: A combination of the two. say two speakers in series, and one hooked up alone, but all to the same amp outputs. Bridging your amp/speakers basically lowers the resistance of the circuit and makes more current flow, more power, louder, harder hit. In series, it also makes both speakers do exactly the same thing, instead of "stereo sound" or L/R differences. What you're probably looking to do is Bridge in parallel. That will drop the resistance of the circuit the lowest, allow the amp to put out the most amount of current to the speakers, and allow your bass to hit the hardest. If your amp only has one output, hook up the same way as above. Just see what resistance your amp is stable down to. If down to 1 ohm, no worries. if stable only to 2 or 4 ohms, you may want to bridge in series to be safe. That will cause the resistance to go up, and will not pull as much current through the amp. The whole time, just remember Bridgeing and higher current mean HEAT so watch your amp. I hope this helped.
Oct 31, 2007 | Pioneer TS-W301R Car Subwoofer
Car Audio & Video Logo
111 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
