Question about Tomtom ONE GPS Receiver
Tom Tom not working
Turn it on and get a few drum beats and nothing else-suspect internal battery-does this when plugged into 12v
When i have tried to update my software by using the tom tom cd it will now not come on. you have to remove the card and put it back in or if its on charge the the tom tom will come on
. help please the
Posted on Mar 31, 2008
SOURCE:
Same stupid problem green is on when plugged in i have sound to turn on with drums beating but no screen have only used the chargers provided when i bought the tom tom i havent even used it in probably 4...
If you have no screen on, then i think you might need to replace the unit and hopefully it is still under warranty. But if not try this, turn the unit on and look very closely at the screen, change the angles and see if you can see a very faint image, if you can, then the unit is working but the backlight display is not working. If it is the backlight display it could be caused by something as simple as a loose connection, or it could need replacement. Hope this helps
Jun 15, 2010 | Tomtom ONE GPS Receiver
Tom tom keeps turning off ?????
The internal rechargeable battery has failed; they don't last forever.
Just search "TomTom One XL battery" and you'll find the the parts and step by step guidance on what to do.
May 28, 2010 | Tomtom One XL GPS Receiver
Hi I have tom-tom one XL (no sd card) model, it wont turn on,replaced the battery then ok next time nothing. But if I unplug the battery and connect again ok until I switch if off, I have to unplug battery...
Hi happyivan8 i know tomtoms answer to this problem is to plug it in to the computer for a few hours but thats not really a fix, just an added pain in the rear.
i have 2 of these and one worked good after i updated it but the other still has the same problem and will only start after i charge it via the usb cable or unplug and plug the battery back in.
try updating it through tomtom home but it may or mayneo solve the problem. if you have already tried the update and that didnt help, i dont know what else you can do other then use it for target practice like im going to.
you can get tomtom home HERE if you dont have it already!
bill
Sep 27, 2009 | GPS
GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Jun 01, 2009 | GE Profile Harmony DPGT750EC Electric...
Have tom tom for car,need to wire it up to m/cycle
I've wired my tom tom for use on a motor bike.
you CANT run 12v straight into the tomtom, you can see on the cig lighter plug it has a 5v output.
So I bought cheap lighter socket, it looks like plastic tube with the cable running out of the back.
So the wires run from the battery (via an in line fuse) to the cig adaptors, these are hidden in my side luggage bag to keep dry and up to the tomtom. job done
Apr 20, 2009 | Tomtom ONE 3rd Edition GPS
The screen will not switch on
If you plug your Tom Tom into your home computer, you should be able to tell if it's going to turn on. It will charge, plugged in to your computer. If it works that way, you can suspect your lighter/utility plu in the vehicle.
Jan 26, 2009 | Tomtom ONE GPS Receiver
Recently after working one day the next day when i tried to use mt tom tom 710 it wouldnt switch on but the mains light was lit when plugged into cig lighter
Try giving it a full charge. I used different model Tom Tom that would not turn on even if plugged in until after the battery was recharged.
Oct 10, 2008 | Tomtom GO 700 GPS Receiver
Tom Tom 910
Either faulty / corrupted files on the hard drive or a faulty hard drive ( not uncommon ) is causing this problem. Effectivley causing the TomTom to lock up as it cannot procede . In order for a tomtom to turn off normally , it needs to have fully loaded up normally. Your tomtom isn't loading up properly , hence the problem. If you have a backup of the tomtom hard drive ? ( I hope you backed up the files to your PC ) then you can try formatting the tomtom hard drive and copying the files back to it from your PC .
Good Luck.
Aug 19, 2008 | Tomtom GO 910 GPS Receiver
Tom tom 3
This is a battery save setting.
Check settings under Battery Saving Preferences, choose Never Turn Off Screen
Apr 03, 2008 | Tomtom ONE GPS Receiver
Tom tom go 500 wont power up
Press the power button for 15 seconds and your tomtom will turn on with the drum sounds yor tomtom will now reset but nothing will be deleted off it and it will now hope fully work.
Bye
Apr 27, 2007 | Tomtom GO 300 GPS Receiver
Tomtom ONE GPS Receiver Logo
99 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
