Question about Lexmark X1270 All-In-One InkJet Printer
Wil only Print from a program - will not open to use all in one scan, copy
When I go to open the lexmark icon so I can scan or copy it gives me this
"Entry Point Not Found Get product prefix @lxkproductatsa7avcstring@@xz could nto be located in Dynamic Link Library LXCZUTIL.DLL
Also: AIOC exe has stopped working
I just bought a brand new dell computer with vista - and my Lexmark all in one 6 months ago - now Dell wants to charged me $249.00 so I can add this software - what a rip off. Cann YOU HELP ME
  • 1 more comment
  • stevebrock06 Mar 22, 2008
    The procedure entry point ?GetProductPrefix@LxkProduct@@SA?AVCString@@XZ could not be located in the dynamic link library lxczutil.dll.
    i have uninstalled, reinstalled, uninstalled and reinstalled it says it has completed the installation correctly however no matter what i do i cant seem to get my printer to work please help.
  • jellp Mar 29, 2008
    I also have a lexmark x1250 all in one, I have brand new computer with vista and I'm having the exact same problem, so i was wondering if you know now how to fix this problem?
  • breno0506 Jan 21, 2009
    similar problem here, will print but not scan pictures or documents. mine is a Lexmark X1240 all-in-one, same message.
    Genius:
  • 3,587 Answers
Ok..first things first..remove the old s/w from control panel..unhook printer
go here for freshest driver
those ones that come pre installed MAY or MAY NOT be most current..
Posted on Mar 22, 2008
How do I connect the 4 in 1 machine to my pc? What goes where? Thanks, Carol
hi
if you installed the drivers and applications , using the CD set the printer came with, all you have to do is read the manual as how to use each application, for instance , to print , slect a document or image and press print , found in top left corner , in FILE.
if you need to scan, lift the cover, place a document or image on the glass, press the scan button, or go the software portion (START, PROGRAMS, locate LEXMARK) or go the bottom right corner, slecet LEXMARK icon and the program opens up exposing all the details as what you wish to do.
if you want to copy, again repeat above (SCAN) and slecet copy, etc..
here is the link to download drivers, suers guide manual and to help you set up the printer
http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X2470&focusedTab=PUBLICATIONS#1
i hope this helps you
Nov 14, 2010 | Lexmark X2470 All-In-One InkJet Printer
My scan button does nothing. How can I scan?
When you press the "scan" button on the lexmark, the scanner is trying to connect to a specific software program that in this case you may not have installed.
You will want to try to test the scanner driver directly.
For windows XP and Vista, try the following.
1. Open your start menu
2. Select Control Panel
3. Select "scanners and cameras"
NOTE: for windows Vista, make sure you are in "classic view" to see scanners and cameras.
4. Check whether there is the lexmark listed in this window.
For windows 7, you will need to do something a little different.
2. go to All programs
3. Open "windows Fax and scan"
4. Click on "new scan".
5. Check whether there is the lexmark listed in this window.
If there is no lexmark, you need to check the lexmark website for drivers. If the lexmark is there, try double clicking the icon to run the scan wizard.
Thanks,
Pat
Mar 31, 2010 | Lexmark X2330 Printer
I KEEP GETTING THE ERROR MESSAGE ''CANNOT RETRIEVE APPLICATIONS LIST. I AM USING THE LEXMARK 5650 PRINTER AND MY OPERATING SYSTEM IS WINDOWS XP.
I went into my computer, clicked on the printer icon and opened it up. Then I was able to scan simply by pressing scan on the icon, It took me thru the Print wizard and I was able to scan without any error message. So now, my printer will print, scan , copy and sort. I am still enjoying the idea of the all in one printer. So, thanks for your offer of help.
Dec 20, 2009 | Lexmark X6170 All-In-One InkJet Printer
Don't know how to scan multiple documents and save
Here is the website for downloading your manual.
http://www.lexmark.com/publications/eng/1200/index.html
It may be able to help you. If it solves your problem please give a good rating.
May 01, 2009 | Lexmark X1270 All-In-One InkJet Printer
Artcopy 55?
To resolve this error, complete steps A and B below. Step A:
  1. Open Windows Explorer.
  2. Go to C:\Program Files\LexmarkX73.
  3. Delete the Artcopy55.jac file.
  4. Open the Scan & Copy Control Program. (Go to Start, Programs, Lexmark X73, Scan & Copy Control Program.)
    The file will be rewritten with the latest settings.
Step B:
  2. Go to C:\Windows\Twain_32.
  3. Delete all folders except for the Lexmark folder.
  4. Reboot the computer.
Note: If completing the above procedure doesn't resolve the problem, JETSOFT recommend reinstalling Windows XP as a solution. (JETSOFT is the company that developed the Scan & Copy Control Program.)
Apr 10, 2009 | Lexmark X73 All-In-One InkJet Printer
My Dell (vista) computer does not see the lexmark x2500?
I got a new hard drive. The disk will not install. So I need to install. I have a Lexmark 3-into-one 2500 series.
Apr 06, 2009 | Lexmark X2500 All-In-One Printer
I have the Lexmark 3430. Print and copy works but it will not scan.
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie Lexmark 3430) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 02, 2009 | Lexmark X2500 All-In-One Printer
I HAVE AN INSTALLED LEXMARK X4270 PRINTER BUT CANNOT FIND INFO ON HOW TO MAKE IT SCAN A DOCUMENT AND COPY AND PRINT IT. COULD YOU EMAIL ME SUCH INFORMATION?
Dear sir
when you install this printer you got one icon call scanner on my computer it's your scanner clink on it and go stape-by-stape then when you scan fine is put it go there then open it and print it..
simple.. if u need more help please contact feel free.. thianks..
Dec 15, 2008 | Lexmark Refurbished 43J1000 Laser Printer ...
Lexmark printer
Do you want to do a copy of a document directly from the scanner? OR copy a document to your pc?
If you want to do a copy - print it out directy, just press the copy button on the printer / scanner, this is covered in detail in the user manual.
IF you want to copy the document to your pc you need to press the scan button or open a program on your pc, for example microsoft paint - and get from scanner or camera.
Aug 20, 2008 | Lexmark P3150 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
528 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
