Question about Samsung PCN5425R 54" Rear Projection Television
Not having much luck with this convergence
I purchased a new convergance board. I installed it but when I go to menu and try and align the cross hairs in convergance set up they dont move when I am using ch up, ch down, vol+, vol- they will switch to different crosshairs using 2,4,6,8
I was letting the TV warm up for approx. 30 min and than the TV began powering off by itself. I would power it on and it would go off before a minute
  • Jeff Peabody Mar 22, 2008
    Premtech,
    I plugged in all the plugs nice tightly they even ship a new 24v +/- wire and the other wide plug wire with the new boards. I was using the factory original remote. I have taken both TV sets out to a repairman for estimates. I sure hope it isnt to much to fix them. Hopefully he can fix one with parts from the other fairly inexpensively or find that my inexperience or lack of knowledge can fix both sets pretty reasonably. I was going to offer him to fix one and keep one if it was a fair deal.
  • 934 Answers
MrPeab,
Is it possible you missed one of the wire connections on the convergence module? My other thought is, are you attempting this setup with the factory original remote or a universal?
Bill
Posted on Mar 15, 2008
I have a Toshiba CT-90121 and my convergence is off. I can adjust the blue and red in the menu but cannot aline them with the green crosshairs. Do I need a new green projector or something else?
You need to remove the convergence Board and repalace the convergence IC's and and replace electrolytic caps and check for resistors that have changed in value. You can getb the parts at www.mcmelectronics.com com or just purchase a new board at www.partstore.com .
Oct 07, 2011 | Toshiba 65HDX82 65" Rear Projection...
I hav a RCA model D52W25 its 52" it has convergence problems dont know how to setup the color things can u help??
Click on the following link :
http://www.riddledtv.com/repair/RCA.html. Go to the following section
(2) (3) (4)
(5) Stretched Image at top and bottom edge very distorted. Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link: Alignment Procedure (pdf)
Also download the Alignment procedure pdf file. Hope this will help you. Please let me know if the information was of any help to you or you need further assistance.
Thanks
Oct 08, 2008 | Televison & Video
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
Unable to align cross hairs on the blue lense. Dose the lense need to be replaced?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
May 08, 2010 | Hitachi 50UX57B 50" Rear Projection...
Words have shadows and yellow is also blue ex football game yardage lines are yellow and then there is a blue line words are not sharp
Not familiar with this particular model but it should have a convergence menu. If so, try using the convergence menu (which is basically a cross pattern (possibly multiple ones) that you use as a reference to align your colors and make the cross pattern white. When you go to this menu and see the cross patterns, if you see the shadowing of the colors, you will know what I'm talking about. If this adjustment(s) don't work, you may have a problem in your convergence board circuitry. Wish I could be of more help but try the menu.....I've fixed 2 or 3 sets like this now. Good luck!
Jan 25, 2010 | Pioneer PRO-520HD 53" Rear Projection...
Replaced convergence board, but can't adjust convergence
Bad chips or faulty soldering....
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 10, 2009 | Zenith R40W46 40" Rear Projection...
FL231 Fuse not blown
check the convergence power supply board for blown reistors. Thats the upper left board when looking in the rear.
Jun 09, 2009 | Televison & Video
Hi I am having the convergence problem with the rca 52" projection. I checked continuity for the FL231 Fuse and it tests fine. I soldered the flyback even though that looked ok as well. I now have the...
Hi. you will need to replace the entire convergence board in this case. the stk chip or, convergence IC is damaged. i will list the part number below. RCA Part Number: 271860 Unfortunately. the actual individual components for this board are not available.
Jun 09, 2009 | RCA R52WH73 Projection Television
Mitsubishi VS-50501A convergence problem. The image looks like a bow tie and the convergence will not align. This TV only has manual convergence. I already replace the STK391-020 ICs, it has 3 of them....
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Red/Orange looking picture
You can see some more examples and find a fix here
Feb 15, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
