Question about Sony Ericsson K800i Cellular Phone
Hp IPAQ- when I tap the screen with the stylus it wont recognise this. It is not locked either. reset it does not work.at a loss what to do.
  • 50 Answers
Using a regular business card, run it along the surface of the screen and work the corner of the card gently under the glass where the glass meets the device body. Do this around the entire edge of the surface There may be some dirt under there that could be affecting your input.
If this doesn't do it, then I would suspect that the Ipaq's digitizer is finished and you'll need to spend some money to get it replaced.
Posted on Mar 14, 2008
SOURCE:
Align screen problem
Ref. HP ipaq hx4700: "Align screen" after hard reset or battery loss. I know others have had trouble getting past the "align screen" setup; I saw a suggestion somewhere that said the points were registered incorrectly (maybe in some, but not all of this model?); and they had to tap at locations other than the center of the cross symbol. I tried a variety of combinations, and found that if I tap ABOVE the center (but still on the vertical centerline) for the middle, top left and top right locations; and tap BELOW the center (but still on the vertical centerline) for the bottom left and bottom right...it worked. That brought me to the "Stylus" setup screen...which I also became "stuck" on. So far, I haven't found a solution to THAT issue yet. Gee, why can't they make these things simpler?
Sep 21, 2011 | HP iPAQ HX4700 Pocket PC
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
Touchscreen not reacting to stylus but the buttons work ok
  1. urn on your HP iPAQ Pocket PC.
  2. Use your stylus to tap on the "Start" menu.
  3. Tap on the "System" tab.
  4. Tap the "Screen" icon.
  5. Tap the "Align Screen" button.
  6. Tap the center of the cross-hair object carefully at each location as it moves around the screen.
  7. Tap "OK" to complete the screen alignment.
Mar 28, 2010 | HP iPAQ rx5915
On IPAQ hx2700, how do I do a hard reset? I want
loaded are stored.
functionality.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
Hp ipaq h6315.can't use the stylus, it's lock.
hi thanks for using fixya!!
Try to make a hard reset of your ipaq, then try all over.
Regards!
Apr 24, 2009 | Computers & Internet
How do you hard reset a hp ipaq rx5915?? i lost the password
. Press and hold the Quick Launch and Rotate Screen buttons.
2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until
the device restarts.
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the
Reset button.
The HP iPAQ restarts and powers on
Jan 31, 2009 | HP iPAQ rx5915
Screen is locked
Mine hp ipaq also froze up, but I tapped the screen until they moved around all in alignment, and I got the basic things back (my programs, Media Player etc. but I can't sync it with my computer. It doesn't recognize the name of my handheld.
Aug 04, 2008 | HP iPAQ HX2755 Pocket PC
Can't get soft reset screen on Ipaq travel companion rx5915
Try This:-
To perform a factory reset and return your HP iPAQ to factory settings:
1. Press and hold the Quick Launch and Rotate Screen buttons.
2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button. The HP iPAQ restarts and powers on.
Mike @ compurepair.
Jul 23, 2008 | HP iPAQ rx5915
HP Ipaq 4700 stylus problem
ask HP yet, we are not HP , sorry and this thing is legacy retired product , what good is it?
here is the real HP forum
see if you can get tears there.
https://h30434.www3.hp.com/
Dec 02, 2017 | HP iPAQ HX4700 Pocket PC
Locked out of my ipaq
  • press and hold the Calendar and WiFi buttons
  • while holding those buttons down, press and hold the reset button for ~2 seconds
  • When the HP iPAQ screen begins to fade, release the Calendar and WiFi buttons first, then remove the stylus from the reset button.
  • Press reset again.  (Or, plug the device into the AC adpater.)
  • The Pda is now hard reset and restored to defaults stored in the rom memory. the password and everything else should be gone and it should work as if you had just opened it for the first time.
    Jan 16, 2008 | HP iPAQ rx1950 Pocket PC
    Sony Ericsson K800i Cellular Phone Logo
    Top Sony Ericsson Computers & Internet Experts
    Andrew Taylor
    Andrew Taylor
    ray gallant
    ray gallant
    Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
