Question about Garmin iQue 3600 GPS Receiver
IQue 3600 sim card problem
I'm trying to dowload maps from my PC to my iQue 3600 using Palm Desktop. All of a sudden it doesn't see my 1 gig Sandisk card in the iQue. It has always recognized it before. Any suggestions?
  • 3 Answers
From Garmin:
Question:
Why wont the PC recognise my the SD card in my iQue 3600?
--> Answer: Go to My computer and look for the following directory:
  • C: > Program Files > Palm > (user name) > file called 'sync'
  • Double click on this file and delete the four bottom rows that will look something like this:
"SlotId=0
MediaType=1935960423
DisplayName=SecureDigital (SD) Card
InstallDirName=Slot-SD"
  • Then try a HotSync as normal, it should then 'see' your SD card.
  • If all fails delete a second user name as sometimes this interferes.
Posted on Mar 29, 2008
Is there a way to use ique 3600 with windows 7? ique does not syc.
I am using Windows 7 Ultimate 64 and the iQue did not work. There is no USB driver and as far as I know there isn't going to be one. However, I did get it working by installing Windows XP mode and the Windows Virtual Machine on my XP system. You need to check if your computer can run XP mode and there are Microsoft tools to do that. After you get XP mode installed and running, there will be a virtual XP window on your desktop. Plug the iQue in its cradle and plug it in to the USB port. Use your iQue setup CD to install the Palm desktop in XP as you normally would. At some point, you have to tell XP to attach your iQue to the USB port. Near the XP title bar, there is a USB pull-down menu. Use this to attach the device. It will ask for a driver. Just say to use the Garmin-supplied driver. Wait until this finishes successfully. Before trying a sync, open the Palm desktop and go to Hotsync/custom and change everything you can to "handheld overwrites desktop" and save this. Push the hotsync button on the cradle. If it doesn't connect, go to the USB pull-down and click attach. It should work!
Dec 08, 2009 | Garmin iQue 3600 GPS Receiver
1 iQue 3600 no Installation Disks or anything else.
You can download for free the installation disk software from www.garmin.com. You can also download a base map, but may have to buy maps from Garmin for more detailed maps/charts. You may need the serial number of the unit to unlock the maps, this is on a paper sticker under the gps antenna.
Mar 06, 2009 | Garmin iQue 3600 GPS Receiver
IQue3600 maps unavailable
You can get City Navigator 2008 CD from your local Garmin dealer. Cost around $100.
It updates via MapSource program and USB connection to IQue 3600.
Do not get "NT" maps as 3600 does not understand "NT" compression
Sep 23, 2008 | Garmin iQue 3600 GPS Receiver
Garmin hotsync issue
Hey uninstall the program, download the newest one available and try again.
Sep 08, 2008 | Garmin iQue 3600 GPS Receiver
Unlocking IQue 3600 maps
Even with the maps unlocked it they can appear to be locked.
There are little known flags to diable/enable the base/detailed maps.
Check that the boxes are checked under the <Map><Options><Misc>
You can select either base or detailed maps there.
Disable both and it looks like the unit doesn't have any maps.
Aug 21, 2008 | Garmin iQue 3600 GPS Receiver
Garmin ique 3600 mapsource Synch problem with XP
Are you running Vista? If so, contact Garmin for a download that allows the maps to be loaded.
Apr 13, 2008 | Garmin iQue 3600 GPS Receiver
Sync problems with windows vista
I got a Vista computer in April and have problems also. You need a special program to install the maps. email Garmin and they will send you the link. An SD card reader/writer is MUCH faster than the sync.
I didn't have syncing problems until after I tried to install Documents to Go. I had to remove Doc to Go v6 because it was making my computer unstable. Doc to GO V10 works with Vista but requires Palm OS6. Garmin says that Palm OS6 can't be installed on the Garmin iQue because they added proprietary software to OS4. I believe my sync problems will disappear after I reload the Palm Software.
Feb 18, 2008 | Garmin iQue 3600 GPS Receiver
Why will my Garmin not sync into my computer?
First, right click the hotsync button in the task bar and make sure "USB" is selected (assuming you're using USB...).
If that doesn't work, let me know.
Oct 06, 2007 | Garmin iQue 3600 GPS Receiver
Garmin IQUE 3600 unable to HotSync, Windows XP
I think I have solved this problem.
Try this:
Go to my computer, right click -> Properties -> Hardware -> Device Manager.
Locate your IQUE 3600, or Palm.
Now, if your palm has a Yellow Exclamation mark on it, that means that your computer is not recognizing the Palm. Select
Driver details. Re-install the driver off the "Setup CD" that came with your IQUE 3600.
This worked for me.
Sep 21, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
137 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
