Question about Mitsubishi VS-45607 45" Rear Projection Television
Tv is green
Hi my t.v has greenlines going through it from side to side and the picture is green looks like i'm watcthing hockey being played on a pond and not at rink .my t.v is old but what a same to put to rest is there a fix to this problem.thanks
  • Mitsubishi Master
  • 8,617 Answers
Check the resistors on the green crt pc board. remove one leg of the resistors to check. if none of these are open. You will no doubt need a new CRT. If you end up needing one I have a source for projection CRTs at really reasonable prices. But check those resistors first as that may be the problem. Especially the resistors right next to the adjustment on the Green CRT pc board often these go open.
Posted on Mar 15, 2008
What is the difference between field hockey and hockey?
Field hockey is a sport that is generally played by girls on a field using cleated footwear. Hockey is played on ice on ice skates or in an area for roller skates.
Jan 14, 2013 | Sport & Outdoor - Others
Where can I play air hockey online?
this is a really cool website and you do not have to register and go through registration processes, simply play, you can try: http://www.candystand.com/play/air-hockey-extreme
Jul 09, 2012 | Sport & Outdoor - Others
Phillips Magnavox 9P6040 C104 tv color adjustment help
If you turn color off and stand back and examine the screen---if it is not black and white but yellow looking you have bad Glycol in the blue picture tube which is quite common.
Easy way to know for sure is with set on and rear cover removed peek with a small mirror at the three lens---don't touch anything with the set on===each tube red,blue, green should have a picture with the set on.
Likely you will find the blue one looks like a floodlight with little or NO image/picture.
May 18, 2012 | Hitachi Televison & Video
Hi, I have an LG RZ-20A70 TV and when i watch TV or play xbox the side are cut off the screen. (think its the picture ratio) any idea how to change this? as i have tried everything!
yes it is a picture ratio issue .
You need to look for the main menu tv setup button, its green on my lg remote .
Once you select this you should have an option to change screen ratio to 16.2 or wide screen if your tv supports wide screen .
Look for a little tv icon on screen and select that ,this should get you to pic set .
Jun 16, 2011 | LG RZ-20LA70 20 in. LCD Television
Black spots on TV when watching sports etc that have white in the picture. The black spots are showing up on the ice for instance (Hockey) all over the TV.
I SUGGEST CLEANING THE LENS ASSEMBLY. IF YOU LOOK ON THE SIDE OF THE TV CABINET YOU WILL A SMALL SQUARE THAT IS ABOUT 4 INCHES BY 6 INCHES HELD IN WITH ONE SCREW IF YOU LOOSEN THAT SCREW YOU WILL BE ABLE TO GET INTO THE CABINET OF THE TV AND CLEAN THE LENS GOOD LUCK
Jan 06, 2011 | JVC HD-52G786 52" Rear Projection HDTV
Picture problem with a rca home theater model p60752eb
I have a problem with the colors on my RCA Home Theater model #P60752EB. I believe it to be faulty tubes or something cause my green and my red color is messed up to the point it will not come in at all.what should i do to resolve this problem without replacing the tv
Feb 15, 2009 | RCA P52926 52" Rear Projection Television
Greenlines on pcl5415r
I suspect the convergence ics bad. samsung takes stk ic cost if you had it done is 250.00 If you can solder you could replace them , part are 30.00 total
good luck doctor video
May 18, 2008 | Samsung PCL5415R TV
Sony KP-57WS500
the unit needs the convergence ic's replaced and probably a couple of safety resistors.average repaire are about 300 from a tv shop
Mar 04, 2007 | Sony KP-57WS500 57" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
29 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
