Question about Sony KP-61XBR48 61" Rear Projection Television
TV wont turn on
I have a SonyKP-61XBR48 and when I turn it on I can hear the start up sound but then the standby light starts flashing. It starts off as 2 flashes then it flashes 7 times and repeats. The TVwas a little cold when I brought it inside and plugged it in and sometimes when I plug it in it turns on by itself. I am not worried about that part it is just that it does not turn on now. The place I got it from had it in use and it worked fine and the first time it turned on I heard sound but no picture and now there is nothing. Any help would be great.
  • Dawnj588 Mar 04, 2009
    Wont come on standby flashes 7 times can you help it is a Sony
    KP-61XBR48
Please post the link with the manual. My KP-61XBR48 wont turn on at all, blinks steady with no pattern or sequence.
Posted on Jul 17, 2008
  • Sony Master
  • 8,617 Answers
2 blinks is Over voltage protection and 7 blinks is high voltage shutdown. You will need the service manual to even begin to diagnose this set with two codes. Let me know if you need me to post a link of where you can get the service manual.
Posted on Mar 14, 2008
Sony KP-61XBR48 wont turn on
Hello!
You should open the tv and clean the cirucit using the blower and fix some connection. if this not work you should test your circuit for the faulty parts of the tv.
melnavz
Mar 14, 2008 | Televison & Video
I have a 55" sony
According to the manual (you can see it here) page 122 that describes 3 red flashing lights:
"The lamp cover is not attached securely. When you secure the lamp cover, the POWER / STANDBY light flashes in red and the LCD projection TV enters the standby mode (see page22)"
Page 22 says:
"... if the POWER / STANDBY light flashes continuously, this may indicate the display unit needs servicing..."
Most DLP displays make use of a "color wheel". These small motors spin at many thousands of RPM. They often begin to make scratching sounds when they are beginning to fail. Some manufacturers make it difficult to change yourself - and others make it pretty easy.
I hope this was at least a good starting point for you & good luck. Please rate my reply. Thank you.
Apr 04, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
It wont turn on anymore. it fires then instantly shuts off, doesnt even flash screen. standby lights still flash and its trying to turn on, just cant get on. you can hear the on sound and then the tv...
Depending on the age of your tv, if you hear a rapid clicking, it seems like your ballast is starting to turn on your tv but it's not able to. (1) Check your lamp, (2) reset the lamp timer, (3) make sure the cover panel is all the way. the positioning sensor might not be detecting the cover all the way in.
Personally I think you're experiencing a ballast problem.
Apr 20, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
No picture or sound, flashing standby light, will not turn on
sounds like powwersupply issue. repair is usually reasonable from reputable repair shop. id say around 150 - 250
Jun 02, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Picture wont come on screen
this problem is in the power supply.the red lights indicate as the standby mode.
Jan 23, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
standby button blinks no picture no sound have tried to reset and restart nothing has worked to get tv to back on
Mar 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
331 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
