Question about Philips Magnavox Learning Universal Remote
Vcr eject manfunction.
Tape will not eject,then unit shuts off.Symbol appears for cassette but under menu it says no cassette.I put in code again just in case,check plugs,turned power strip off then on again.Please help.
    Champion:
  • 230 Answers
Sound like you have to open your VCR and help it left up to eject. I had the same problem.
Posted on May 15, 2008
The VCR accepts the tape and starts to play; then stops and shuts off; when you turn the power back on the tape ejects
You have a transport problem, the mechanism the plays, FF or rewinds is not working.
Someone is going to have to open and look at the unit---as simple as a belt off or broken to the idler (rubber or geared) that doe the actual work, finding a shop that will work on a VCR unit is getting hard as most of the current techs have never seen this type of unit.
What I used to do when I opened one was have a old cassette with the tape removed! but the reels inside of it still there--tape off both sides of the cassette where it opens so the sensors on either side do not try to stop the unit from allowing this.
This way with the unit open and the dummy cassette in you can see thru its top to see if the reels are moving or not and not have the tape get in the way.
Dec 06, 2012 | Magnavox DV220MW9 DVD Player VCR
Error 02 - 574
Main code 2X : Mechanism control system error
574 Failed to detect the T reel FG during search.
This means the take up reel stopped rotating during forward search. It shut down assuming tape was spooling loose into mechanism. Could be just a faulty cassette tape. A common problem is also when labels have been placed in the wrong places on the cassettes, stopping the lid from opening fully and stopping the reel reaching the reel motor drive.Manually eject the tape and try another tape. If the fault continues, have a look for something in the way under the cassette such as post it notes, paper clips, torn labels etc.
Have you had the unit serviced since you got it?
Could be time to get it to a service centre for help.
Aug 06, 2012 | Sony HVR-1500 HDV VCR
VCR tape loads and runs about 5-10 sec; then ejects
you need to clean the vcr with a cleaner that you can buy at a store. If that doesnt work then you need to take the 4 or 5 skrews out that hold the top on and look at the motor and gears move while you put a tape in and you should spot the problem pretty quick. It'll be with the round metal wheel that turns the tape.
Jan 02, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Tape/Display problem
Straight from the manual:
C:21:ss Moisture condensation has occurred.
-> Remove the cassette and leave your camcorder for at least one hour to acclimatize (p. 291).
Mar 12, 2008 | Sony Handycam DCR-PC101E Mini DV Digital...
Cassette
Most VCR's will auto-rewind the tape when it gets to the end of a tape. Most will leave the tape in the unit assuming you may wish to view it again once rewound. Does the tape eject properly when you press the eject button? What does the manula say about the eject function?
- Jim
Jan 23, 2008 | Philips VR550 VHS VCR
CST.IN Light
Put a tape in and eject it. It will then work. Just had this problem. CST IN means the VCR thinks it has a tape in. Trust me... Very fixable.
Jan 19, 2008 | Hitachi DV-PF2U DVD Player/VCR
Tape stuck
Your takeup spool isn't moving.  Before tearing into it further try putting the cover back on the deck and power cycling it.  Hit REW and then try ejecting the tape.  If this works, you'll get the tape back but it's likely the deck is dying.
If not, you need to be very careful to get the tape out:  You may be able to turn the wheel that moves the tape basket to gently ease it out;  otherwise, there are screws on the top of the tape basket.  Remove them and gently lift the tape out while carefully unthreading the tape from the tape guides around the head.  There'll be two feet of exposed tape--pretend it's glass, it's delicate!
Now the tape is out and you need to thread it back in the cassette.  This needs patience, but here goes:
On the front of the cassette, there's a door to protect the tape.  Feel the right hand side of the cassette for a small button;  hold it down to open the door and keep it open
With the other hand (or with three hands! :) ) put your hand under the right-hand tape reel under the cassette.  Carefully turn it clockwise.  It will make clicking noises, but it should ease the tape back into the shell.
Beyond that, the cause of the original malfunction will be a bad reel motor, which is probably not fixable, or a bad belt, which you may be able to locate through mcminone.com.  You'll have to unscrew the bottom cover to investigate further.
Oct 20, 2007 | Televison & Video
DSR-1800 Lost Lock
This error 07.042 means Detected the abnormal capstan speed.here what u have to do go to maintanence menu.and check the capstan speed
Sep 28, 2007 | Sony DSR-1800 DV/Mini DV VCR
Tape witll not play
your tape player may be jammed up and not playing your cass.
Jul 04, 2007 | Sony Walkman WM-FS593 Personal Cassette...
Vcr not playing tapes, just ejects them
Not enough info. What is the product? Brand, model, how old?
May 13, 2007 | Philips MWD2205 DVD Player/VCR
Philips Magnavox Learning Universal Remote Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
