Question about Sewing Machines
Maybe a timing issue?
My Singer 14sh654 serger has a problem I can't figure out. When I turn the hand wheel, it makes a clunking noise like metal on metal. When I try to sew, the knife won't cut the fabric (although it's in the correct place and it's sharp) and the thread bunches up on the fabric. Have a suggestion? or should I take it to the shop? Thanks for your help!
  • Sewing Machines Master
  • 1,388 Answers
If it sounds like metal on metal, it probably is......
Unplug machine, remove all threads and SLOWLY wind handwheel in the normal direction for sewing (usually anti-clockwise for more modern machines)
To locate the collision point, watch carefully at the three possible points for any collision...take the needleplate off to get a better view,...........if you see or feel the point of impact, DO NOT FORCE the handwheel, just note the details.
1. When the two loopers pass. their relative position left and right is critical, as is the distance apart from front to rear....these are not inexpensive to replace, so do this slowly and listen and watch.....this is the most expensive when it goes wrong as you risk breaking one or both loopers.
2. When the Lower looper swings behind the needle/s it may hit the needle, the tolerance here is 0 - .05 mm, so it is really crucial to get it accurate........if there are needle guards involved as well, they also may be hitting the needle.....risk is generally only to needles breaking
3. Least likely.....When the Upper looper passes the needle/s, though the clearance here is far more liberal
The needle bar height is also a crucial factor..as this dictates the relative position for all other movements and timing.
I have just looked through a service manual for a similar machine made by Janome/New Home, and realistically...all in all, without the service manual to refer to and perhaps some specially manufactured guages to get fine settings correct, this is not a job for the novice without someone on your shoulder to talk you through it in my opinion......if you break either or both loopers, that's half the service fee already spent most likely.
As to the other issues, they will all be resolved by a competent service technician in the course of a standard service.... for this one, I think money well spent.
Posted on Mar 15, 2008
The wheel on my Singer overlock is hard to turn and its making a lot of noise.
when a machine starts making noise then the machine needs to be check to see why
May 21, 2012 | Singer 14SH654
Left needle not stitching on serger model 14SH654.
the needle could be damaged,,replace the needle,,if the needle is new make sure it's in the needle holder correctly
Aug 26, 2011 | Singer 14SH654
ViraI have misplaced my sewing machine manuel and I need to know how to use my Singer Finsihing Touch Serger 14SH654.
FREE INSTRUCTION MANUAL DOWNLOAD
Go to the singer website
Go to the home page
At the bottom of the page look for instruction manual--click on it
It will take you to another page
In the box put the model number (example 14SH654 ) & click search
They have a free download--they have 2 free downloads you'll have to see which one you need
Aug 15, 2011 | Singer 14SH654
Lower looper problems
Some sergers require they be threaded in a particular order. If not, they do not "knit" the threads.
Raise the thread antenna to it's highest position.
Open the tensions (set at zero). If the tension settings are automatic, raise the presser foot to open the tension settings.
Turn the handwheel so the loopers are at their highest position. There may be a mark on the side of the serger to match up with a mark on the hand wheel for this.
Open the front of the serger and the threading guide should be printed on the inside of the serger door, or on the serger.
Start at the right and note which looper is threaded first and then the needles.
You can find more information and manuals at the Singer Co website.
Mar 24, 2010 | Singer 14SH654
Need manual for singer 14u52a this is the right model # not 14sh654 thanks
You should also try www.sewusa.com. I found the manual for a used Necchi 521FB I brought. Hope that helps.
Feb 11, 2010 | Singer 14SH654
Singer 14SH654
Either it's not up all the way or your timing is off. Check needle first
Aug 21, 2009 | Singer 14SH654
Cutting knife adjustment
I have found this info...it mentions both threading and changing the knife width. I hope it is useful.
http://www.singerco.com/pdf/14SH654_threading.pdf
Mar 17, 2008 | Singer 14SH654
Sewing Machines Logo
239 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
