Question about GE Profile PDW8400J Built-in Dishwasher
GE Profile built in dishwasher problem
Our fairly new dishwasher isn't working all of a sudden, for no apparent reason. Rather than the time it will take to run the selected cycle (which is usually what is displayed) the display reads Ih, or maybe I and an upside down four; And although the buttons are all lighting up when pressed (even the start button) it won't start.
Got any ideas?
  • Kelwos May 20, 2008
    Got any ideas?
  • 54 Answers
Try cutting the breaker off for 5 min, This will reset the control.
Posted on Jul 04, 2008
Ge profile dishwasher not cleaning
Our GE dishwasher never did clean correctly. Then it died. WE bought a new dishwasher different brand . New dishwasher is cleaning great clean dishes now. GE Dishwashers sucks!
Nov 10, 2013 | GE 24 in. Profile PDW7800 Built-in...
My GE profile dishwasher is not draining, is it fixable?
Yes, it is fixable. I would fix check to make sure the float on the inside of the unit is not stuck (not a probable, but easily checked). Then I would pull the unit out and check the pump. If something is clogging the pump intake then it wouldn't drain. If there isn't something blocking the pump intake, then it is probably the pump itself.
Sep 20, 2011 | GE Profile 24 in. Built-In Dishwasher...
Have a new GE Profile dishwasher. The LED time display started at 62 the first time we used the machine. It keeps going up and is now at 108. Is it broken and how do we reset the time back to something...
Have you tried to turn the mains power to dishwasher off and back on again.
It also possible the inlet water temperature is not at the recommended temperature so it is compensating for heating it to the desired temperature. Please check if your installation guide says you use cold water inlet or hot water inlet.
Try running on one of the eco cycles first to see if the heater is the cause. Eco cycles use lower temperature inlet water.
Dec 03, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
Dishwasher will not drain. Used compressed air and blew the drain hose. After that, dishwasher worked fine for a couple of cycles. Then problem started again.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 24, 2010 | GE Profile PDW8400J Built-in Dishwasher
My dishwasher will not drain. Have not installed a new garbage disposal or new dishwasher. Just all the sudden stopped working
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | GE Nautilus 24" Built-in Dishwasher
Water is sitting in bottom of dishwasher after cycle is completed - fair amount of it
Hi
Thanks
Rylee
Oct 22, 2009 | GE Profile PDW8000G Built-in Dishwasher
I have a GE Profile Triton Dishwasher and it has worked fine for about 8 years. Suddenly it will not reset. The reset light blinks after reset but you can not choose a normal cycle afterwards. I shut of...
Hello, how are you?
It sounds like you have a stuck key on the keypad, preventing you to push any other key.
I've seen this problem many times in the past 4 years.
Good luck.
Ned
Sep 20, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Profile 7880 will not drain
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to some different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then you may want to consider calling a professional plumber. He may need to replace the drain valve or hose.
Thanks
Rylee
Aug 29, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Profile Dishwasher beeping
Mine was doing the same thing. It was eligible for a recall.
Free repair or rebate toward new purchase. 1-877-275-6840 or go to website geappliances.com
Jul 01, 2008 | GE 24 in. Profile PDW9200J Built-in...
I talked with a GE techy, and was told to either turn off the circuit breaker or unscrew the fuse for the power to the dishwasher, wait 45 seconds, then turn the power back on. GUESS WHAT? IT WORKED!!! try it.
Mar 17, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE Profile PDW8400J Built-in Dishwasher Logo
479 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
