Question about Dell Axim X3 Pocket PC
Axim x30 screen blanking
When external power is connected, screen blanks
I've seen this twice>
take battery off pc and plug it in.
if it stops replace the battery.
if it does not your charging circuit in the pocket pc is gone south.
Posted on Jul 25, 2008
SOURCE:
Dead pixel line?
Hi, The problem with pocket PC is that you can't do something to test and find if the problem comes from the display or the graphic processor. If the device is not too old, you can try to repair it. In case that the device is more than 10 years, buy a new one. Sorry.
May 30, 2017 | Dell Axim X30 Pocket PC
My sony handycam dcr-hc20 screen is blank
check my details on repairing a similar camera in the DCR-HC family:
http://www.rubbishworld.com/repair_DCRHC_complete.pdf
It may or may not be a solution, but I hope it helps!
Apr 15, 2010 | Dell Axim X30 Pocket PC
No wifi, how do i get on internet
This model of the Axim X30 does not have built in wi-fi capability. You need to purchase a 802.11 b/g Wireless SDIO card.
IMPORTANT: DO NOT INSERT SDIO CARD INTO AXIM X30 BEFORE INSTALLING DRIVERS.
1. Connect the Axim X30 to your computer.
2. Establish a connection between the two devices using Active-Sync.
3. Insert CR-ROM which ships with the SDIO card in your computer.
4. Follow instructions for installing Driver an Utility.
5. Install SDIO card into the SD slot on the Axim X30.
May 16, 2009 | Dell Axim X30 Pocket PC
MY DELL AXIM X30 WILL NOT TURN ON
My Axim X30 would not turn on using battery power but would turn on when connected through charger adapter.
Solution:
1. Connect AC adapter directly to the charger adapter and then to the Axim X30 and to the electrical outlet.
2. Charge battery until power button is solid green.
3. Press the power button to power on.
4. Remove cable from cable connector leaving the cable connector connected to the Axim X30. The Axim X30 will remain powered on.
5. Turn the Axim X30 off.
6. Turned the Axim X30 on using battery power.
7. Remove cable connector from Axim X30.
Apr 07, 2009 | Dell Axim X30 Pocket PC
X30 time error scynchronization
Have you got the correct time zone selected in the Regional Settings on the Axim?
If you have the time showing on your today screen click on it and you'll be presented with a screen showing which zone you have.
Mar 17, 2009 | Dell Axim X30 Pocket PC
Delll axim x30 screen remains dimmed even though fully charged
ok , you have checked the brightness settings, check battery power settings as well. you may have to do a hard reset so back up your info. If doing a hard reset, pull the battery and charge it on its own if you have a cradle. Hope this works for you
Feb 28, 2009 | Dell Axim X30 Pocket PC
Cant connect to internet using my dell axim x30 helppppppp
http://www.fixya.com/support/t1775615-connect_internet
just answered this for someone else, if you have any other problems get a hold of me on twitter @clarkb16
Feb 23, 2009 | Dell Axim X30 Pocket PC
Lost CD Rom for my Axim x30. Anywhere I can download it?
You need ActiveSync from Microsoft. Unless you're using Vista which uses Windows Mobile Device Center. Connecting to the Axim to a Vista machine should automatically download the Windows Mobile Device Center software.
ActiveSync for XP and older systems can be downloaded here:
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-synch.mspx
You'll proabbly still want to update your Axim's firmware and drivers if possible.
Feb 04, 2009 | Dell Axim X30 Pocket PC
Screen frozen with vertical lines
same problem
if anyone has any suggestions, it would be appreciated.
Nov 18, 2007 | Dell Axim X30 Pocket PC
Dell axim x30
HI You have two ways: 1) Install the ActiveSync (Version 4.2 is recommended) PC Software with your PC first Next, you connect your Axim to your PC. Then you install the software or game into your PC. it will also install into your Axim automatically thru Sync process. 2) Or install the software or games into your External SD Memory card thru USB SD Card reader. Then put your sd memory card into your Axim and run the software or game. The 2GB or 4GB SD Card is reccommended since the game or software sometime is huge. I hope it is help. Regards, pingping
Jun 14, 2007 | Dell Axim X30 Pocket PC
Dell Axim X3 Pocket PC Logo
118 people viewed this question
Ekse
Clive
Clive
