Radioshack Remote does not work with Sanyo TV
I've been trying to make my remote to work with my Sanyo TV (TVS-2530M). I've followed the directions as they are in the manual but the codes doesn't seem to work. I already set it up with my sony dvd and works fine so I wanna know what the problem really is with my tv?? can you guys help me??, can you give me the right codes?? please...!!!!
image of my remote...
http://img340.imageshack.us/img340/283/dsc02956wz6.jpg
THANKS!!
SOURCE:
SOURCE: Sony RM-V310 compatibility
BEKO TV CODE HELP
Posted on Mar 06, 2008
SOURCE: Direct TV Remote code for Sony ICF-CD555TV
I used 0111, it worked
Posted on Oct 02, 2008
SOURCE: Sharper Image Jumbo Universal Remote
you press the code search button and keep pressing the power button until your tv powers off
later i will add a link to get other info.
Posted on Mar 17, 2009
  • 814 Answers
SOURCE: Sanyo tv,RCA universal remote,Diamond Vision player--compatible?
Sorry it took so long to respond to your request for assistance. You can find the instructions and codes you need to program your television at the RCA customer support website [http://www.rcaaccessories.com/rcaaccessories/ ] Copy this web address and paste it into the address bar of your web browser. This will take you to the RCA main customer support page. Just go to the universal remote control section and find your model remote control. Use the model number to find the technical support information page. On this page will be a copy of the owners manual and the remote control codes to use with your products. I hope this information helps you with your problem of needing instructions and codes to use your remote with your products. Thank you for using FixYa and have a nice day!
Posted on Jun 22, 2009
SOURCE: Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
Posted on Nov 28, 2009
Can you give me the codes for a sanyo tv for a universal remote
try this link...4 digit GE codes for TV sets including LCD, Plasma, and Panel TVs Brand Code SANSUI SANTECA SANYO SCOTCH 224 more rows
4 digit codes for TV sets including LCD, Plasma, and Panel TVs - GE ...
www.eliztech.com/remotes/ge-4digit-tv-codes.php codes for sanyo tv for universal remote Google Search
Dec 09, 2016 | Sanyo Televison & Video
Need remote codes for sanyo tv
press the helpful button Step 1 Insert two AA batteries into the universal remote control if you haven't already done so and then turn on your Sanyo TV. Press and hold the "TV" button on the remote until it lights up.
Step 2 Input the following three-digit codes into your remote control one by one using the remote keypad: "004," "013," "049," "108," "110," "180" and "209." The TV will turn off when you enter the correct code for your particular Sanyo model.
Step 3 Press the "TV" button on the remote once more to confirm the code after you've identified the correct one. You can now use the universal remote to control your Sanyo TV.
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Jan 27, 2016 | Sanyo Televison & Video
Sanyo remote missing, direct tv won't work until I can select input on tv manually
You can buy a replacement remote with all of the features of the original here: http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=DP26649&uuid=13965609760310 . This remote is guaranteed to work with your TV. Alternatively, a universal remote that was programmed after April 2010 with an input button should have a code that will work allow that button to work with this TV. You may have to try multiple codes.
I hope this helps.
(The DP26649 was available on Amazon.com starting before the end of October, 2009. Most universal remotes can control TVs made 6 months or more before the remote was programmed at the factory.)
Apr 03, 2014 | Sanyo DP26649 26 in. TV
I lost my remote to my sanyo plasma and my picture is stuck in zoom. I've already bought a universal remote that has a pic. zoom button but does not work for my tv. How can i get my picture down t
push minue directly on tv and seif that works. try to see if you can get it out of that mode. you might need the origanal remote. try search on the remote control may work
May 16, 2012 | Sanyo DP42746 42 in. Plasma Television
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
What is the four digit code for the radioshack 3 in one low cost universal remote control for the sanyo tv?
The 4 digit code for the radioshack 3 in one low cost universal remote control for the Sanyo TV are 0154, 0088, 1907.
Jun 12, 2010 | Radio Shack (15-2147) Remote Control
Programming my directv remote to operate this tv, codes dont work
I just programmed mine by using my direct tv remote...
Go to MENU on the direct tv remote
Then highlight HELP & SETTING and press SELECT.
Press SELECT on Remote in the left menu.
Simply follow the onscreen instructions to program your remote. IT IS IMPORTANT TO MAKE SURE YOU HOLD ON AND SEE THE GREEN LIGHT ON THE DIRECT TV REMOTE FLASH TWICE, otherwise it won't work....which is what I think is happening in your case. Good luck.
Apr 22, 2009 | Sanyo DP42848 LCD TV
Hello; I bought a RCA replacement remote at Walmart last night. It is model RCR312W I have a Sanyo 15" TV that is connected directly to cable I tried programming the code into the remote and it...
The universal code for most is 049 for a Sanyo TV. With your universal remote you press the code search key until it illuminates and then you press and release the TV key. Next enter the three digit code (3 digit remote code page) and the indicator light turns off.
If you enter in the wrong code the light will flash rapidly. Aim the remote at your tv and press the on/off key. If your tv turns off then you have found the right code!
Try these codes for your Sanyo TV also: 054, 069, 023, 025. If those do not work then also try: 004, 013, 049, 108, 110, 180, 209
http://codesforuniversalremotes.com/universal-remote-control-codes-sanyo-tvs
The best solution is to buy a replacement remote for the make and model television that you actually have.
https://www.replacementremotes.com/SANYO/Remote-Controls
Feb 10, 2018 | Televison & Video
Need Philips Universal Remote Codes for a Sanyo TV
Hi Pamr
Try the Phillips website >HERE< which links to their Universal Remote support centre. Unfortunately you haven't given the details of your actual remote but you should be able to find it and download a manual or email them direct.
Sanyo TVs use all these codes:
0506, 0311, 0612, 0002,
0428, 0802, 0412, 0619,
0208, 0157, 0292, 0036,
0011, 0370, 0072, 0216,
0217, 0104, 0045, 0009,
0163, 0037,
Sorry there are so many, but one should work.
Best wishes...
Mar 23, 2008 | Televison & Video
Radioshack 3-in-one remote code
the panasonic codefor my radioshack 3-in-one remote is 0250
Feb 27, 2008 | Radio Shack (15-2147) Remote Control
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Ekse
