Question about iiyama Prolite E430 17" LCD Monitor
No menu Hi, i have a problem with the iiyama I bought 5 years ago. It always worked fine, until recently: the menu "CONTRASTE" comes on the screen, goes by itself to zero, and won't go away, making it difficult to see what I'm working on. All the menu buttons are not reacting, just the Power button seems ok. I tried to unplung it, then switch it on while pressing the + and - buttons, but nothing happens... The screen turns on, and 2-3 seconds after, the menu "contraste" appears. It goes away by itself for a few seconds, and then comes back. What can I do to get rid of it?
  • maxxo Mar 16, 2008
    Thank you for your quick response!
    As it was Saturday, I decided to try to fix
    it myself. Taking out the front of the screen was quite easy. There is a hidden
    fifth bolt under the leg, it took me some time to figure it out.
    As you said, the “– “ button seemed stuck,
    but not with the front cover. The defect was inside the button. I tried to
    press it many times, and it just worked: the annoying “CONTRASTE” on the screen
    disappeared. The menu button still does not work, but it’s not a problem.
    The screen is now ok.
    Thank you again for your accurate advice!
  • 55 Answers
One of the buttons on the front of your monitor is probably stuck.
(Only one of the buttons work at a time on most monitors)
I cannot recommend taking it apart your self (have a tech do it)
But take off the front, check the buttons after you take off the front, and if it still occurs unplug the buttons from the monitor.
If it stops (which it should) replace or fix the controls)
If it doesn't, call an exorcist (just joking) or buy a new monitor.
Posted on Mar 15, 2008
Not starting
It will be best to contact any service technician in this case. Gopakumar Gopalan Google
Mar 18, 2014 | Vizio 32" M320VT Razor LED LCD HDTV,...
My KF60XBR800 will not always power up when we
Replaced the projection lamp again.Sony projection lamp more expensive,but last longer too.Genaric projection lamp brand last about 1 1/2 max.U hear clickinng sound too,when LED light flashes?Mean the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
Jul 07, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
The ipod nano 4th generation will not display anything nor can music be heard. Just bought six hours ago. Fully charged and can play music loaded on ipod through computer but no display just blank screen...
This happened to me. For some reason, these ipods go into a deep sleep sometimes. Make sure that the hold switch it is off. Try holding down the menu button until it comes on. If it doesn't come on with that try holding down the select (middle) button until it starts up.
Dec 19, 2008 | Audio Players & Recorders
DEAD IIYAMA AS4636D
Hi Sammy7!!
I have such iiyama AS4636D monitor. In this day purchase.
I have such problem with you.
My solution:
Desktop pc and lcd power off (230VAC or 110VAC)
Power on lcd, after early desktop pc.
This moment, when running the pc booting, press and hold you the " + " button.
In this moment come in one blue screen. May be running on the sreen short message: check or select input mode: VGA DVI 1 2 . Select your correct cable connection type.
Have a nice day! and happy new year!
Lajos from Hungary
Dec 13, 2008 | iiyama Pro Lite AS4636D (Black) 18.1 in....
Vizio, Model P4, manufactured in 2003 -- worked fine until 5 minutes ago
I have the same tv and the same problem. The power switch in the front flashes a bunch of times, but nothing else happens. Have you had any success in getting yours fixed?
Sep 08, 2008 | V, Inc. Vizio P4 Plasma Television
PC monitor wont come on.
Check that the power cord is fully plugged in first.
It is probably the inverter board inside the monitor.
(if the screen does properly display ever then it is not the screen)
It CAN be fixed but I do not suggest anyone open up a monitor (LCD or CRT) who is not "technically inclined."
If you really want to fix this particular one then take it to a local tech and get an estimate first. If it's almost as much as a new monitor then buy a new one.
Mar 14, 2008 | iiyama ProLite E434S 17" LCD Monitor
Startup hangup
Try upgrading the firmware.
Mar 10, 2008 | Sony Ericsson P990i Smartphone
CM2015 15" LCD Monitor
Sometimes over long periods of tiem these buttons on the LCD monitor become lodged and they begin to stick. From frequent use the board that controls these small charges that allow the board on the mother board to know what button is pushed shortout or go bad, the pads beneath them go bad as well. You may want to purchase a new monitor! I repair these all of the time, sometime you just have to say goodbye! Sorry!
Nov 26, 2007 | Balance CM2015 15" LCD Monitor
Vertical lines across the screen
Change ballast and lamp at same time. Ballast #75006507 lamp #23311153
Sep 11, 2007 | Toshiba 46HM95 46" HDTV
iiyama Prolite E430 17" LCD Monitor Logo
457 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
RS Technology...
RS Technology...
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
