Question about Acer Aspire 1200X Notebook
Won't go past the BIOS page
Whenever i turn on my laptop it keeps on resetting itself and wont go past the bios page. i once got it to work and i system restored it, but during the process it shut down after it did its restart. i tried to turn it on again and it still resets itself.
if you have a solution please mail me @ [email protected]
  • jjmaster Mar 14, 2008
    oh my laptop is an acer aspire 1200X
  • Anonymous Apr 29, 2008
    i have a dv9000 laptop and i have the same problem, it restarts itself after 20-30 seconds. i tried to press power off button until it shut down and after shutting down immediately pressed power on for 0,5 seconds and it worked. but after some time (about a month) this method resullted in another problem. yes, i got a long beep and two short beeps which is about video card problem.
    Scholar:
  • 105 Answers
Hard drive may be faulty - try removing the hard drive and reboot. It may take a while searching for the missing hard drive but it should eventually move on and show - operating system not found. If this is the case then either your hard drive is faulty or the windows installation is corrupted.
Posted on Mar 15, 2008
SOURCE:
Gateway 9310 xl how to reset bios
Turn on your computer and keep hitting the F2 key until you have the option (or are automatically put in) for entering the BIOS setup.
Once you are in, you should be able to hit F9 to select a reset for your BIOS, there may also be more options to reset once you are in.
I am not working on a Gateway so I can't be more specific, sorry.
Nov 30, 2014 | Computers & Internet
Hp pavilion dv9000 takes a long time to get past the bios screen. It won't boot of dvd either??
Check BIOS boot options and assign local hard drive as first for faster boot. This is also where you set CD\DVD as first to boot from disc. Look for F Key press on start up. It will be shown on screen. These can vary.
Many HP machines also have a boot menu option during boot. Again an F key and may vary.
Sep 22, 2012 | HP Pavilion dv9000z Notebook
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook: My Hp laptop turned off by itself and wont turn on...
Make sure your Notebook is not overheat if it is then you have to make sure the fan is working and have to work on the NB by placing it on a hard surface and also BIOS update will also help to resolve the issue.
if in case the notebook is not overheating boot to BIOS screen and check if the Notebook turns off by itself in bios if it does then its a hardware issue and you need to contact manufacturer to service the notebook
May 18, 2010 | HP Pavilion dv9000z Notebook
My HP Pavilion Dv6700 turns on but nothing on the screen as in its black, BIOS do not show. Please help!
Looks like the post itself fails on the system from what you have told here. Its easy to reset the bios. Download the actual bios flash program on a completely formated usb drive. Fix the usb on your laptop and keep fn+esc keys pressed and switch on the laptop. It will rewrite the bios and once rebooted the system should work. Good Luck.
May 05, 2010 | HP Pavilion DV6700Z Notebook
Turn it on and it wont boot
You need to re-flash bios. I had the same problem and this fixed it!
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
(Bios can be downloaded from: http://bit.ly/gUf2a)
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS. Source: http://bit.ly/MbbHP
Jul 10, 2009 | Acer Aspire One A150-1006 Notebook
Laptop webcam wont turn off,
If you don't want to use it at all you can disable it in BIOS. Otherwise you can disable it in device manager, or on whatever programs runs it.
Jun 12, 2009 | HP Pavilion dv7-1130us laptop
System /bios password
Try removing the CMOS battery. Keeping 3/4 minuets will reset the bios password.
Apr 22, 2009 | Computers & Internet
MY COMPUTER WONT START UP!
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Jan 13, 2009 | Acer Aspire One PC Notebook
Acer Aspire 1200X Notebook Logo
56 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
