Question about Sony Handycam HDR-UX1 DVD Camcorder
Mini dvd's not recognized by pc
I have a brand new Dell 1510 laptop running windows xp. I have a sony hdr-ux1 that I used to record onto mini dvd's. I have tried playing some (but not all) of the discs on my computer using various dvd players, but none of the players wil recognize the discs. The dvd drive just makes chunking noises and nothing happens. And yes, the discs are finalized and they do play on the handycam. The discs are one sided dvd-rw discs. One of them is even a sony disc. Any suggestions?
I had a similar issue at first... needed to ensure that I had the Sony Picture Motion Browser Software downloaded to the system and then it was ok.
Tom.
Posted on Oct 20, 2008
SOURCE:
Can't read DVD+R that were recorded on LG-DR389 on my PC / Laptop DVD
The DVD+R is the older version that was used, all newer ones use the DVD-R now, your problem is the disc is not recognized in the other players because of the different format.
Mar 18, 2012 | LG Televison & Video
Hi there cannot connect i link to my pc no connection on my pc any advice would help
Usually what you would do is buy a IEEE-1394 interface card and install it in your PC in an available slot on the motherboard. You can buy these for less than $20 and with a little tech knowledge about PCs many people can install the card themselves. The IEEE-1394 is called i.Link by Sony. If you are running Windows XP, or Vista, the drivers are already installed. Reboot PC and the new card should be recognized. Use the 4-pin to 4-pin firewire cable to connect camcorder to PC. You will need software to capture your video which should have been supplied by Sony with your camera. For Windows 7, you need to install LIVE Photo Gallery. Your camcorder was setup to work with Windows XP so an alternative may be to just find a friend with an older PC with a firewire card already installed running Windows XP. I just did this very same thing on my PC and it worked. Got the firewire card from Amazon.com for $3.95 VIA brand from Taiwan. I used Windows Movie Maker to capture video. Sony also sells a stand-alone DVD recorder which connects to a camcorder and requires no computer to create DVDs of your video.
Mar 18, 2011 | Sony Handycam DCR-HC24E Mini DV Digital...
My laptop updated with window xp now bluetooth is not working for dell vostro 1510
Is your 1510 compatible with Windows 7? Did you check the list? http://www.microsoft.com/whdc/hcl/default.mspx
You will also find a hardware test routine you can run on your computer.
Jun 08, 2010 | Dell Vostro 1510 Laptop Computer PC...
I have a High Definition Sony Handycam - HDR-HC5. I am currently having major problems trying to use my firewire "i-link" cable to download the holiday tape onto my pc for editing. Each time the...
Go to manufacture's website. Find the download or support tab. Then look for the very latest drivers for your camera. Then download onto pc, double-click to extract and install the driver, then restart pc, Then turn on camera first, then start any programs you are using, then finally connect with usb/i-link/HD cable.
When pc doesn't recognize a device, it is due to the driver.
Nov 16, 2009 | Sony Handycam HDR-HC5 Camcorder
Unable to read dvd-rw from sony camcorder - wants to format
I had a similar issue. I could not read the camcorder dvd drive (sony hdr ux5) from my computer. I even tried several different computers, it reads the drive but cannot recognize the format. I made sure the disk was finalized, but did not help. Then I found the this article http://forum.videohelp.com/topic351360.html which suggested I down load CDRoller which I did (14 day trial version), finally I could read the drive on the camcorder dvd drive. Hope this helps you, if you have not fixed it already.
Sep 11, 2009 | Sony Mini DVD-RW 1.4GB 30 minute ( 8cm - 3...
Playing back footage on pc
don't know u're cam, but usualy the camera haz to "close" the dvd sesion, so that the computer/dvd player .... to be able to play it ...
Ofecourse u can play the video on PC, using cd/dvd data recovery software, that accesses the data directly and not track based ... (that in the case that the dvd got damaged and the recorder can't finish it ...)
Feb 17, 2008 | Video Cameras
mini DVs sometimes can't be access using usb interface, try to look if u have a firewire interface, be sure your laptop supports IEEE1394. power dvd is the best player for dvd files. -r means recordable, not rewritable (rw). if ur not familiar with video editing, you may not be able to burn it to disc, but you can play and watch everytime.
May 17, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Sony Handycam  HDR-UX1 DVD Camcorder Logo
285 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
