Question about Hifonics Brutus BXi 1206D Car Audio Amplifier
Hello i have a similar problem with my amp i opened it up and i can see the parts that are burnt....but i have no clue what they are and how to fix it...if you could help me out call me at 214-695-9945
  • Frank Fulton
    Frank Fulton May 11, 2010
    Is the amp out of warranty?
How can I fix the red shadowing that's on the screen
That's probably your convergence misadjusted. You can go into the TV menu & adjust the convergence. If you are not able to converge properly, then you most likely will need to replace both convergence ICs & the resistors that have burnt open. Unless you have the wherewithal to perform the parts replacement, I highly recommend a professional do the work.
It is also possible that the pins of the convergence ICs have unsoldered themselves, due to heat. If you catch this before they cook themselves & open the resistors, you can avoid the process of replacing ICs & resistors, but usually it's too late.
May 01, 2014 | Toshiba 56HM195 56" DLP HDTV
What kind of battery does a '87 dodge colt E need?
Hello! an AutoCraft Gold, Group size 34/78, 800 Cold cranking Amps is an excellent choice...Part No. 34/78-4.....cost is about $110...
Part No. 34/78-4
Dec 29, 2011 | 1987 Dodge Colt Vista Wagon
I have a 2001 sentra gxe with the following fault code P0350, P0113, P0183. The ignition coil have burnt out twice, the car stalls & the engine shakes severely when started. I have been advised to...
P0350-Ignition primary and secondary circuit malfunction.
P0113-O2 circuit slow respose
P0183-Fuel temperature "A"High input
They say 3 is a for P0183 the temperature circuit is disconnected (this is a clue),P0113 circuit of the 02 slow response (this is a clue), P0350 secondary and primary that leads to a (clue)
You have wires touching where they should not be touching. If you replace ECM and Coil it will just come back with the same problem,who every you take this for repair they need to recognize this as a shorted wire harness and see it as one unit,not just read a code.This is tied as one , have them open the wire harness to the affected coil not all the way just enough to see if it shorted out, My suggestion is to check and make sure the conection to the coil is not loose and all connection for coil is not loose,
Apr 27, 2011 | 2002 Nissan Sentra
I have a kicker zx550.2 it started to smoke . Is there any way to fix
to be honest you can. but is it worth it no.
because the repiar cost will be more than purchasing a new one, you more than likely fried the circuit board
Mar 25, 2010 | Kicker ZX550.2 Car Amp
My 12v touched my ground last night and big spark happened
hello sound to me you may have burnt the main power wire to the body or other metal on the car ..
if i was you i would first check the fused if there not popped trace the wire from the battery to the amp see if you can find a burnt spot on the wire it should have a burnt spot on the ajasent part of the car.. untell you find that wire it will drain your battery "try to disconnect the amp wire from the battery recharge or jump start your car run your car for 20 mins" that should fix your car... if you have questions
Dec 20, 2008 | Solid Audio Formula Series F2000 2-Channel...
Pioneer SD-P4552 turns off immediately after turning on
Good Day, vash4056;
Don't dig a hole yet I'll will have to some more research.
Okay?? big IRISH.
Aug 07, 2008 | Televison & Video
Xplore 2ch 200w amp model 4090 help
Yes there's a way to fix that. The best way to fix that is to bring it to your supplier (if it has warranty and in terms and conditions) or to a certified repairman in your area.
Jun 02, 2008 | Power Acoustik LT-980/2 Car Audio...
Rockford Fosgate P3001
See if you can read any markings on this part. If you can't, maybe a photo might provide a clue.
Sep 28, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
Hifonics Brutus BXi 1206D Car Audio Amplifier Logo
88 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
