Question about Dryers
No heat for dryer
Model no. inside door of dryer is 76932692 brand is kenmore 90 series. problem just started no heat at all turns on with no problem, no noises just no heat.
  • Anonymous Sep 28, 2008
    Their is no heat coming from the dryer hotpoint tdc32 electric dryer
    Scholar:
  • 178 Answers
Need to look at replacing the thermostats and heating element whaich are accessible behind the dryer in a small panel. Be very careful to watch for sharp edges and disconnect the power before you do ANYTHING else. It's a relatively easy fix and you can get the parts feom www.marcone.com
Posted on Mar 14, 2008
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
I HAVE A KENMORE 90 PLUS SERIES DRYER. IT DOES
check the door switch and also check the belt,if the belt breaks there is a switch inside that turns the dryer off
Mar 19, 2010 | Kenmore Dryers
Dryer doesn't always start, and doesn't keep running
your have a dieing dryer motor,weak weak to turn the drum anymore,the model number is inside the dryer door if you want to try and find one cheap on ebay-mike
Feb 23, 2010 | Kenmore Dryers
Kenmore series 90 dryer(5 years old). Power ok
have you checked the start button?
Jan 30, 2010 | Dryers
9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Nov 07, 2009 | Kenmore 63942 Dryer
How to remove front panel from kenmore 90 series gas dryer
Gently pry top of dryer in front corner area. Disconnect door switch inside front. Remove 2 sheet metal screws from inside front. Let me know, Thanks, Sea Breeze
Mar 21, 2009 | Kenmore Dryers
Dryer will turn on, but no heat is inside?
Most likely a bad heating element or bad/broken connection.
Jan 01, 2009 | Kenmore 63942 Dryer
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
266 people viewed this question
Top Dryers Experts
Marvin
Marvin
