Question about GoVideo Go Video DVD/VCR Combo
My DVD/VCR DUAL DECK model #dvr4400 remote control was lost. Now the system wont work. it does not power up by pressing the power button and work by using the buttons on the face of the unit. How can I get to work. Can I program an other remote to work with it until I can get another remote control for it.
  • 11 Answers
Have you tried buying a universal remote control? You can get them at places like walmart for as little as $20.00.
Here is the url to the manual. Hope one of these helps!!
Posted on Mar 22, 2008
SOURCE:
The buttons on my DVD vcr don't respond
get a remote,it will be cheaper,I had the same vcr,it did the same thing,a circuit board burned up. Samsung 00008A DVD Remote Control for DVDV3650 DVDV3500 DVDV8080 Tested...
May 12, 2017 | Samsung Televison & Video
I need code(s) for my DVD Video, Model #: NB093 remote control to program my Philips DVD Player/VCR, Model #: DVP3345V/17. Can you please help me? I would greatly appreciate it. Here is a picture of it.
http://remotecodelist.com/remotes/magnavox/magnavox.htm lists the code for your device as possibly being 1000, 1001, 1002, 1003, 1004, or 1005. Of course, you also have the option of using the remote controller's "Code Search" button. 25300580-iv4burzhkawezvl2jbah1xae-2-0.jpg With Codes:
Turn on the DVD/VCR unit directly. Continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Enter the four-digit code (1000, 1001, 1002, 1003, 1004, or 1005) for the DVD/VCR unit. The remote controller's light should go off. Press the remote controller's power button, & when the DVD/VCR unit turns off, then you will know that the remote controller has been correctly programmed.
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
Nov 29, 2014 | Televison & Video
I just got a new Dish VIP 211K system. I am having trouble programming the Dish remote to control my Sony DVD-R/VCR combo system. None of the codes in the book are working with it. I need to program it...
Hello, Cheri Torres with DISH Network Customer Service here.I came across your post and wanted to see if I could help. We have a fewdifferent codes for each of our different models of remotes. I will list herefor you the best codes for the more popular models of remotes and also theinstructions for addressing the remote to the TV. The best codes for the SonyDVD/VCR are 817, 778, 818, 768,005 and 002. I hope you find these codes andinstructions useful but if you do not I will also list here for you theinstructions for running a power scan which can sometimes find the code foryou. If you have any other questions or concerns feel free to email me [email protected] :)
Instructions for addressing your remote to your DVD/VCR
  1. Press and hold the desired Mode button until all mode button backlights come on, then release.
  2. Use the number buttons to enter the device code corresponding to the equipment. AUX Mode: Before entering the device code:
    • Press 0 for a TV
    • Press 1 for a VCR/DVD
    • Press 2 for any other device.
  3. Press the pound (#) button Note: The light will blink off after each digit is entered and then return to a steady light.
  4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Instructions for running a power scan
  1. With the desired equipment on, press and hold the correct Mode button until all mode button back lights illuminate, then release.
  2. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button
    • Press 0 for a TV
    Then Press STAR (*)
  3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
Feb 09, 2011 | DISH Network ViP 211 DTV Receiver
Just hooked up my new Magnavox DV220MW9 DVD Player ? VCR Recorder. I was able to set the time and a vcr timer program but now I can't switch the source. It now comes on as the DVD but neither the remote...
You need to release the timer to access the VCR. Press the Timer Set button on the remote or the Stop/Eject button on the recorder. Then press the VCR button.
Please note: the scheduled recording will not run as programmed unless you press the Timer Set on the remote again. (The timer locks the VCR until the scheduled ON time.) The DVD player is controlled separately and becomes the default unit.
I hope this helps.
Oct 04, 2010 | Philips Magnavox DVD/VCR Dual Player
My olevia tv and Ge Remote control wont work lost code. Help?
USING CODE SEARCH FUNCTION
If your TV, VCR, DVD, etc. does not respond after you have tried all the codes
for your brand or if your brand is not listed, try searching for your codes by
following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR
LIGHT lights, then release.
3. Press and release the device button for the device you are
programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will
blink once then remain lit. For AUX, press AUX then the device
button you are assigning to AUX.
Feb 01, 2010 | GE JASRM24912 Remote Control
My vcr is not lested with u
Can you please give the model no. of the govideo dual deck..
Jul 10, 2008 | One For All URC-3021 Remote Control
Manual for dvr4400
are ppl still buying govideo ..i heard its a piece of shit?
Jan 26, 2008 | GoVideo Go Video DVD/VCR Combo
GoVideo Go Video DVD/VCR Combo Logo
107 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Ekse
Demonic-2011
Demonic-2011
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
