Question about Vacuums
I have the Bissell Flip Ease (vacuum/mop) and threw away the instrux on how to load the cleaning solution...and I can't get the clear plastic holder off the fixture. Anybody know which buttons to push?
For the water tank - you just pull up on it and forward motion. for the dirty tank there is a button at the top you pull down on.
Posted on May 08, 2008
Was given a Bissell flip-it but no guide to tell me how it works. I am looking for the manual that comes with them when new
User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Jul 14, 2010 | Bissell 52889 Flip-Ease All-in-One Vacuum...
My bissell pro heat clear view is not spraying when I press the trigger. what is the problem? I have check the belt and clean the machine. Is there something else?
I believe the water pump is broken. You can order a new one for about $22 and try to install it (it is located under the plastic near the cleaning solution holder). It requires removing quite a few screws, but if its just the pump, its easier than replacing the valves/solenoids under the water tanks
Oct 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
When i store my bissell flip ease it leaks water all over the floor and it says you can store it with water in it.
It sounds like you have a faulty gasket and to find if this is the problem you will have to find where they connect and look at the gasket/ or it might be a little round rubber ring. If you do find a broken rubber ring take it to your local hardware store and have them match it up and then just put it on and you should be all set or the easiest solution to this is store it empty and fill it when you are going to use it.
Oct 25, 2009 | Bissell 52889 Flip-Ease All-in-One Vacuum...
9500 doesn't pick up water
Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use) and is a small (1 inch square) red plastic filter with a door on it. Flip the door open and it is probably clogged with hair, carpet fibre, etc.. Clean it out and hopefully you will have suction once again.
Jun 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Steam cleaner will not **** up water
Try checking the lint filter. It is located in the top clear plastic section (the section with the dial to switch from floor to tool use) and is on the underside. It is a small (1 inch section) red plastic filter with a door on it. Flip open the door and you will probably find that it is clogged with hair, carpet fibre, etc.. Clean it out and you should have suction once again.
Apr 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Flip it not dispensing detergent
soap probably dried up and clogge the ports,always run clean warm water through the unit till the soap is cleaned out
Dec 02, 2008 | Bissell 52889 Flip-Ease All-in-One Vacuum...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
