Televison & Video Logo
Posted on Mar 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I recently bought a security system for my home. The Camera opperates in standard deffinition. I need to find a DVR to record on a hard drive that will record at least 200, but preferably 500 hours of the digital feed. I am looking as well to spend as little as possible (A max of 1,000 if possable). Thank you Chris
Anonymous
Level 3:
  • Master 431 Answers
  • Posted on Mar 30, 2010
Anonymous
Master
Level 3:
Answers
431
Questions
0
Helped
147202
Points
1209
Hi I am vortash , Just a suggestion but why not just buy a USB video capture device off Ebay and turn an old lap top into a PVR then you can fit an external Hard drive and record for however long the hard drive is capable of ?. You would possibly have greater control of picture search also when trying to find a particular piece of recording . Regards Vortash
How do I hook up my cameras to my Digital Video Recorder (DVR) please?
Question edited for clarity.
Question moved from film cameras to Home Security CCTV.
This question needs make and model of the system. The search query should be 'make model installation'. There is generic help and diagrams in the link.
https://www.google.com/search?q=+Digital+Video+Recorder+connect+cameras
1helpful
I have a Techview QV-3048 CCTV security system and can't get any sound. Any suggestions as to what I've done wrong? Cheers
Question edited for Make and clarity.
Question moved to Home Security.
No sound on this system, video only.
System Specs
Price breakthrough! An affordable 4 channel DVR suitable for day and night surveillance. Includes 500GB of storage for up to 300 hours of continuous video recording from the four 420TV line weatherproof colour cameras with IR illumination. The four channel DVR supports full D1 resolution at 25 frames per second on each channel and can be controlled across the network or by using the included mouse or remote control. Recordings can be initiated manually, triggered by a timer or activated by movement in the camera's field of vision. Connect the DVR to a computer network and you can even view video remotely from anywhere in the world using a web browser or Smartphone/iPhone® (via installed app*).
DVR Specifications:
• Video compression: H.264
• Video input: 4 x BNC composite
• Video output: HDMI, VGA, 2 x BNC Composite,
• Audio input: 1 x RCA
• Audio output: 1 x RCA
• Maximum recording resolution: 704 x 576 (D1) at 25fps per channel
• Maximum recording frame rate: 100fps
• Hard disk storage: 500GB SATA
• Back-up: USB & network remote back-up
• Network interface: RJ45, 10/100Mbps
• Power supply: 12VDC 5A (included)
• Dimensions: 255(L) x 185(W) x 50(H)mm
Camera Specifications:
• Sensor: 1/3 CMOS
• Horizontal resolution: 420TV Lines
• Lens type A (2 cameras): 3.6mm lens, 72 degree angle
• Lens type B (2 cameras): 6.0mm lens, 45 degree angle
• Size: 85(L) x 45(Dia.)mm
• Voltage: 12VDC from DVR power supply
Camera Cables:
• Cable type: Combination video and power
• Cable length: 18m
* Free app for viewing live video available for download.
https://www.jaycar.com.au/economy-network-4-channel-dvr-kit/p/QV3048
Manual
https://www.manualslib.com/manual/596293/Techview-Qv-3048.html#product-QV-3048
How to connect the loops
6 Ways to Understand Security Camera Systems - wikiHow
www.wikihow.com > ... > Disaster Preparedness > Home Security
wikiHowYou can self-install a professional security camera system. ... the systemGet poweredCamerasMonitor(s)High speed internet connection ... after the hard drive is filled with video, the DVR simply loops around and starts from the beginning.
Methods for Recording with Home Surveillance Equipment ...
www.ebay.com > ... > Home Surveillance > Digital Video Recorders, Cards
However, many inexpensive security cameras only come with a way to view the ...places on the tape, continuous loop tapes rarely work with time lapse VCRs. ... If the camera needs to be connected directly to a recording device, then the user ...
Video Ground Loop Interference for CCTV ' 2MCCTV Blog ...
2answers
Outdoor Digital Wireless 2 CCTV camera System 7" LCD monitor DVR Record to SD TF but recorded playback poor what can I do please I am 81
Try recording in a higher quality than standard and see 2hatcthe results are.some of those are low resolution cameras and you won't get a wonderful image out of them.
1helpful
How to hookup audio to home security sys
do you have audio cameras, they don't usually give you the audio cameras with a standard setup, on the back of the dvr there is a plug for audio its either a phono plug or a mic input socket, this can be used in one room or outside depending on the mic you have to buy. you then wire this up to the cctv and have to setup the sound to the camara number.
How to hook up audio
Connect a microphone and enable the audio. It should all be in the settings. Check each camera to make sure audio is enabled. Usually it is off by default.
Bought a Homeland Security System made by MX3 Technologies Inc. which included 4 cameras. The system motherboard keeps going out and now we are unable to record activity. Have tried to contact MX3...
my search did not help, not enough info to do a good search. model numbers may help. the camera number does get info but nothing on the company. you can just get another dvr security system less the cameras and connect these cameras to it and start over. i did that few time just in doing upgrades. the cameras are mostly universal anyway just make sure you connections are the same from the camera to the dvr. sorry i can't help more. but not enough info for a good search. good luck. try ebay for dvr systems for the head unit.
https://www.ebay.com/itm/4CH-Channel-Full-1080N-720P-AHD-DVR-HVR-NVR-HD-2000TVL-CCTV-Security-System-E1V2-/142413186437?epid=28003888764&hash=item21287cc585:g:lCsAAOSwa-dWsC9Y
try this.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
