Question about Casio Exilim EX-Z57 Digital Camera
Lens Error The lens opens with a weird noise. The zoom is blury it wastes my time to get it right and it is very annoying!! What should i do?? i think its a lens error welll thats what it says and then the camera shuts down. What do i do?????
  • vicalcabasa Mar 20, 2008
    i have a casio exilim ex-z57.
    when shhoting pics in normal zoom mode, the pictures in lcd is very bright.
    but when zoom is adjusted to its optical maximum settings, the shots are normal and clear.
    what's wrong with my digicam?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
Camera says
Hi there just like to informed you that 2 reason can make a noise.
1. low or old battery's using.
Solution: replace it if too old or charged it fully.
2. Lens error. Internal lens guide pin if damaged then the camera goes off with bad noise.
Solution: repair or replaced the lens guide pin.
Thanks & waiting for your feedback.
Apr 01, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens error with Casio Exilim EX-Z80 and makes a weird buxxing sound please I need help
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 18, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Camara not focusing/ zoom not working
Its an error code and shows problem of Lens mechanism.
Lens focus / zoom motor is stuck that's why camera gives out of focus image.
You need to replace Lens Assembly and it would cost you more then camera worth.
Oct 26, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Blur image
I am having a problem with blury pictures. Every one I take is blury and it also seems the flash wont go off. Now the pictures are blury even in the daytime. Anyone that can help me please do!!!!
Mar 26, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
CANON POWERSHOT SD400
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Jan 16, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Lens error
This is the lens focus gears. They are either knocked out of alignment, or debris has jammed them. The good news is it can be fixed....Casio most likely won't help. Hint...google my user name.
Dec 24, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Zoom error too
if you spill any thing, like a soft drink,tea,coffee,etc. anywhere around the camera, when the lens barrel is open, it will cause it to stick when it is closed. so when it dries, you are stuck. put fresh batteries in, and with a rubber mallet, lightly tap on the face of the lens, when the camera is powering-up. do not hit it hard. after two taps, my camera lens opened up. you can clean the barrel with some wd-40, with a q-tip swab. use very sparingly. and next time, be very careful where you lay-down your camera. you never know......
Jul 08, 2007 | Fuji FinePix A350 Digital Camera
Blury Display on FE140
It sounds like your lens's focus element is stuck. Given the events you describe it is possible that a grain of sand has worked its way into the focus motor's gearing and jammed it up. Normally the small motor moves the focus optic in and out to achieve proper focus, if its movement is limited or completely jammed you will experience blurry pictures. The camera will have to be disassembled and the sand cleaned out to restore normal function. There are repair providers you can find online who can work on your camera. David Millier Advance Camera Repair
Mar 20, 2007 | Olympus FE-140 Digital Camera
Casio Exilim EX-Z57 Digital Camera Logo
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
