Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Where can I find instructions on replacing a 60v500a light engine?
Trying to find out how to diy a light engine. any help?
Thanks
  • 50 Answers
Take off front cover, and look for lamp door. Remove door, and remove lamp. You will need a long phillips screwdriver. Any questions please ask.
Posted on Mar 31, 2008
How to install lamp
Here is a link to Hitachi DIY LCD TV Bulb and Lamp Installation Guide. It shows the 50V500a and 60V500a lamp location and bulb replacement. Check your user manual for information regarding safety and bulb disposal issues.
easyab
Feb 23, 2011 | Hitachi 60V500 60" Rear Projection...
Lamp light on after i replaced the blown lamp Hitachi 60v500a
Was the tv working before you replaced the lamp? if it was then make shure you have reinstalled the new lamp and the door exactly as removed, there is a disconect switch on the door that has to close when the door is reinstalled,or sometimes the ballast may go bad at the same time.Hope tha t will help you fix it.
Mar 19, 2010 | Televison & Video
Hitachi model 60v500a.the middle of the screen is a little yello
If you Google "60v500a light engine" you will learn a few things about this set which was first sold in 2003.
There are some class action lawsuits out there for several Hitachi models made at about the same time.
Most of the time these sets develop a discolored area fairly large in the middle of the screen---a lot of them had a large red or pink oval area but other colors are possible.
This set uses a LAMP for the light source and it directs the light into the optical light engine--at the top of the engine is a 3 inch lens that the picture comes out of and is directed into the mirror which puts it on the screen.
Lots of these sets develop a "burn" inside the engine from the heat--there are a series of lens and baffles inside---even slight separation inside will change the color in some area of the picture.
I am sorry to give you bad news but I have replaced a lot of these engines under extended and when they were new mfg. warranty.
The part is no longer available from Hitachi new--the only way to get one is to remove the one in the set and have it sent out for "rebuild" and the last time I saw one the engine was over 600 dollars at the wholesale level not counting the fact that it is major labor to replace.
Find someone in your area familiar with Hitachi and this model and you will see what I am talking about.
Even though this is not good news, I think it is what your problem is.
If this helps you, rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Hitachi 60V500 60" Rear Projection...
Hitachi 60v500a projection turns itself off
i have the same problem, did you ever get an answer?
May 31, 2009 | Hitachi 60V500 60" Rear Projection...
Hitachi light motor for 60v500a
Click here to find the part you need for your TV. I would suggest to contact them before buying it and ask them if they could provide you with info on how to DIY.
Good Luck.
Jan 08, 2009 | Hitachi 50VS69 50" Projection HDTV
REAR SCREEN PROJECTION LAMP OUT
google 50v500a bulb or 60v500a bulb... Lots out there...It's a DIY job I think
Jan 03, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
60v500a
Not sure.....Check e994 - its a pico fuse on the main board....If its blown the kit will most likely help. If its not blown the problem is elsewhere.
Nov 05, 2008 | Hitachi 60V500 60" Rear Projection...
Hitachi 60V500A
Good Day, artisticpool;
Suspect loose cable see picture:
If okay suspect light engine.
Good Luck, big IRISH.
Aug 17, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Red spot at center of tv
HI DAVID THE NAME OF PART THAT NEEDS TO BE REPLACED IS ENGINE YOU CAN ORDER THIS ONLINE AND REPLACE YOURSELF FOLOWING EASY INSTRUCTIONS OR .CALL AT TV TECHNICIAN TO DO THE JOB FOR YOU
THE PART COST ITS AROUND $400.00 REFURBISHED
IF YOU NEED MORE DETAILS LET ME KNOW
YOUR RATING OF MY ANSWER IS APPRECIATE
THANKS
Jun 27, 2008 | Hitachi 60V500 60" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
189 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
