My microwave only runs for 37 seconds, no matter how much time you set it to, and then it just turns off. It also does not produce any heat. Once it turns off, if i push buttons on it, they beep, so power does go through, but I can't understans why it's stopping so abruptly, and always after 37 seconds...
Same thing with me....I turn it on it sort of makes a few "poof" sounds a bit like popcorn popping real slow and then stops at around 30 seconds...do you think this is a fuse issue as well? Kimmé
Unplug the Microwave and remove the outer cabinet. Inside the cabinet will be a thermal insulated fuse, looks like the old buss fuses for early model cars but white. Replace that with the correct fuse which can be found at Lowes or Home depot and see if that solves the problem. Be careful not to touch any capacitors if they are in there.
Was this solution helpful? Show your Appreciation by rating it:
