I've just bought a SMC7904WBRA-N Wireless router with a SMCWUSBS-N2 Wireless adaptor. It's probably obvious to you but... I want my pc to have a wirelss connection but can I install the adaptor first and use the wirless connection to install the modem, or do I have to use the ethernet connection to install the modem first then install the adaptor? Regards
  • spongeboy Mar 14, 2008
    Cheers - Thanks for the advice and quick reply.
    Scholar:
  • 178 Answers
Best results would be to install everything from a HARD wire connection. Wireless, can drop bits of data depending on interference. I would definately use the ethernet to install everything and then try the wireless.
Posted on Mar 14, 2008
Netgear zing
This is a wireless adaptor not a router.
Check out the internet connection by directly wiring into the LAN port of the router to the PC.
You will probably find the fault there and have to consult your ISP.
If it is the adaptor, check you have the correct driver software and the distance between the computer and the router.
Apr 25, 2014 | NetGear WG111 802.11g/b Wireless Adapter
I want to change my security password. what shall i do?
This article actually has most if not all the info you are looking for. It should be under WiFi Protected Setup.
http://portforward.com/english/routers/wireless/Encore/ENHWI-N2/wireless.htm
Dec 12, 2012 | Encore ENHWI-N2 802.11n Wireless Router...
Cannot connect to Wireless with my Linksys WRT120N Router.
If you have 2 devices not be able to connect to it suddenly, then it is probably the router that changed, as opposed to it being the 2 devices changing at the same time. Sometimes wireless routers just go bad like that.Try a factory reset, and then set the appropriate settings back to where you need them. If that doesn't help, you likely need a new one.
Feb 09, 2012 | Linksys WRT120N Router
What is network adapter mean
A network adaptor is an interface device that allows your PC to communicate with other computers and the internet. There are wireless and wired adaptors.
Wireless adaptors usually connect your PC to the network through a wireless router and modem. Wired adaptors (also known as ethernet adaptors) connect your PC to another computer, a router or a modem using a cable.
Regards,
Yavacotech
Jan 05, 2011 | Microsoft Wireless Network Adapter Xbox...
Seemlessly joining two networks
try changing the subnet on N1 to 255.255.254.0 or 255.255.248.0
Apr 24, 2010 | Computers & Internet
I don't have wireless network on acer aspire4715Z
The Aspire 4715 comes with Wireless OPTIONAL. Your system obviously wasn't bought with a pre-installed wirelss card. If you want to go wireless, you will need to buy a wireless card/adaptor seperately.
Nov 29, 2008 | Acer Aspire 4720 Notebook
Cannot finish installation (Belkin F5D8633-4 wireless modem router N mimo)
ok, obvious questions first:
Do you have a different modem from TALKTALK? can you connect to the internet through that?
if so, you may not have to set a username and password for the belkin router: just connect the belkin router's internet port to the talktalk modem and let the talktalk modem handle the automatic connection.
do you know what protocol the talktalk ISP uses?  it's probably PPPOE; make certain that your belkin router is set to the correct protocol.  if you just hook it up to the talktalk modem though, you probably won't have to specificy a protocol at all.
Mar 29, 2008 | Computers & Internet
Wireless set-up
No, there shouldn't be any other problems associated with it. What kind of computer are you trying to connect? How old is the operating system not to have an integrated 10/100 mbps ethernet port on the motherboard?
Mar 15, 2008 | Computers & Internet
Netgear wireless connection
Check the wireless IP address on the XP computer. try to ping default gateway and see whether its giving succesfull reply, after that do ping yahoo.com and check successfull pinging. if it pings successfully the yahoo website , then you should go online.
Oct 24, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
For SMC7904WBRA :: How to use Cable Modem on ADSL router/modem combo?
Did you have DSL prior? if so, was the MAC address cloned to the router? You may need to check that setting, its pretty common with this type of setup
Jul 29, 2007 | SMC Barricade g SMCWBR14T-G Wireless...
Computers & Internet Logo
329 people viewed this question
David Payne
David Payne
