Question about Lands Phones
I have an OKTA touch. It has stopped connecting, tried all he usual stuff, differnt ports, resetting etc? any ideas. Used to work fine
  • sandles Mar 15, 2008
    Tried 3 diffent cables and reinstalled WMDC
    Still no joy
  • 2,336 Answers
It looks like you might need to install the drivers again to synchronized both devices. You can also try to clean the contact from your OKTA Touch with alcohol to get rid off dust or oxidation that occurs. I would also suggest to use a different cable if possible.
Do you have the user guide handy?
Posted on Mar 14, 2008
We have a Malibu 300 low wattage transformer for 13- 20 watt landscape lights.
Try connecting a lamp (correct voltage, etc) directly to the transformer. Most likely, the wire from the transformer to your lights is broken... The reset button can't reset anything, if there's nothing wrong there.
Jun 16, 2016 | Intermatic Malibu 300W Power Pack...
My iPod Touch can no longer connect to any wireless network. It picks up the wireless signal, but when I try to connect it tells me I cannot connect to the network. I've tried in free places and at home...
The wireless port of the ipod touch sounds broken. It could be from a bump or drop, moisture exposure. etc. etc. If you've update the software and it still doesn't work, it sounds like a physical problem.
jailbreak can cause wifi issues as well.
Mar 03, 2011 | Apple iPod touch
Receiving but unable to send for approx 14 days. set up on new mail s still unable to send. Message. Protocol SMPT,Port:25,Secure(SSL)No,Error Number Ox800CCCOB
You might check this site: http://www.oehelp.com/OETips.aspx#3
You did not mention whether you were using antivirus software to send or receive filtered e-mail. I tried looking up your error code-and one common theme I saw was that you should turn it off. It causes problems and does no real good since the high end viruses just send directly from their own code.
However, another thing I saw was that people had errors in their setup.
You imply that this used to work and stopped suddenly. You might still try deleting the mail destination and then re-adding it, insuring that your userid and password are specified correctly, and that you have not inserted any extra spaces, capitalized when you should not, etc.
Finally, open a command line and then enter the command:
telnet yousmtpserver.net 25
where you type the name of your smtp server as specified in your isp's connection stuff.
This to test the ability to reach your ISP's smtp server. See, some ISPs block outbound connections to port 25 - to stop spambots from sending from people's home computer. If it turns out that you can't connect to port 25 on your mail provider's smtp server, sometimes they have an alternate port that you can use. By default the "submission port" (which is only supposed to be used by customers inserting mail initially) is 587, while 25 can be used as a submission port or it can be used by another ISP as they transfer mail to you. So you could try telnetting to port 587 or you could try just specifying 587. But first turn off your anti-virus outbound mail filtering and see if that helps.
Feb 01, 2010 | Computers & Internet
My switch used to work fine,D-link DES 1024D
I suggest you reconfigure you network. Maybe your configuration authorizes only one IP adress on the network.
Try to reset your router to defaults to see if that solve your problem. After that you will have to reconfigure the router.
Hope it helps.
Sep 11, 2009 | D-Link DES-1024D Express EtherNetwork...
I-touch wont connect to any web page
Its a last resort, but this is what usually happens when people are in your situation.
  1. Go to settings.
  2. Go to General.
  3. Scroll to the bottom and click on Reset.
  4. Click on Reset All Settings.
  5. Then Click on Reset All Settings. You will have to do this twice. This will reset the iPod Touch to the original factory settings so you will lose some saved information like wifi settings and stuff, but you will keep any apps you have downloaded as well as contacts etc.
Aug 01, 2009 | Apple iPod touch
My Computer and iTunes does not recognize my iPod Touch
Try resetting it while it is connected. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
If you have not already tried, I would also try the other ports on the computer.
Are you running iTunes 8?
And what kind of computer do you have?
Jun 01, 2009 | Apple iPod touch
No gps working
I've got a HTC Touch pro or AT & T Fuze. The GPS worked fine for a few months but lately has stopped working. It was always slow to find the satellites compared to the GPS in my car. I've tried a few programs that were using the GPS tried changing the settings and ports and resetting it, but still doesn't work. I've backed it up was thinking of a hard reset incase it's a software error or else the GPS itself is broken on the device. GPS tuner can search for the GPS and it just searches for ages and doesn't find anything and used to find it almost instantly.
Apr 06, 2009 | HTC Touch Diamond Smartphone
Nothing happens when you touch the screen
If you used it connected to your computer, for upgrades etc., reconnect it and shut it off through the computer before you unplug it. They get captured by the computer if you just unplug them.
Jan 30, 2009 | Tomtom ONE 3rd Edition GPS
GPS/Fishfinder keeps dropping and restarting
Do a software upgrade to the CE33 unit and then a master reset by unplugging the power cable , then press and hold PWR and CLR buttoms while plugging back the power cable. Wait a couple of second while the software reloads and should run smooth....
NOTICE: All the previous data as routes, waypoints, etc that you had will be lost by the master reset.
Jan 27, 2009 | Simrad Ap1601r Elect Only Ap16 Rc36 Rf300...
OKTA MONDO
no these internet unlocking sites cant do it.
Someone here in NZ must have Telecom NZ master operator cade and instructions for this phone. Please help.
May 08, 2008 | Computers & Internet
Lands Phones Logo
323 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
