Question about Gateway FPD2275W LCD Monitor
Monitor goes blank.
I have 2 Gateway FPD2275W monitors, in dual monitor mode on a BFG 9800 GT video card. On one of them, DVI seemed to stop working, so I switched to VGA. It powers up normally, and shows video for a couple of seconds, but then the screen blanks. If I go into the menu and select VGA (I can't see the menu, but I can move through the menus, thanks to having an identical monitor that works...), the power button goes to orange, then the monitor wakes up and shows normal video for a couple of seconds, but then the screen blanks again. Yesterday, it "woke up" for a several-hour stretch, but today, it is back to blanking.
Any help/advice would be greatly appreciated.
  • artmanbill Mar 31, 2010
    I swapped the monitors. Then I moved the faulty monitor to another computer, running Win 7. Same problem. It suddenly cleared up, so I moved it back to its original spot, as second monitor in my studio. It worked a few hours, but this morning, it was back to its bad tricks.
  • 11,361 Answers
Did you swap the monitors to see if the problem follows or stays at the same video output port since you have dual monitors set up? Need verify before opening up the monitor.
Posted on Mar 30, 2010
SOURCE:
How can I use 2 monitors on my GT 4010?
You need a card that will support dual monitor, even if it is VGA and DVI.
Jan 14, 2013 | Gateway GT4010 (RBGT4010) PC Desktop
My monitor seems to be stuck in sleep mode
This happens when there is no communication with video card. Check cables, re-seat video card, make sure monitor is set to correct mode. VGA (15pin blue), DVI (white), or HDMI.
Aug 28, 2012 | Dell desktop and monitor- Inspiron 530...
I tried to set up dual clones monitors and set the display too high for either monitor now i cant see to reset the video display. Is there a way to reset the card to factory setting with seeing the...
Hello dave, the only way you can change default setting on resolution is go to > Nvidia Control Panel > Display > Change resolution and click apply. If this option does not work you can go to start> control panel> uninstall a program and remove your old nvidia driver from you computer and reinstall latest driver again, restart computer. I hope this helps you.
Nov 26, 2010 | BFG Technologies 3DFuzion 3DFR6200LEE...
When cold starting, my comp will run for a few minutes before the monitor glitches, locks up, and goes black. When I reset, the start up screens are garbled with random characters all over. After windows...
the 9800 is a power hungry card  some modles are rated at 450 watts . your computer sounds overloaded by your card. depending what you have in your computer(DVD burner, Second hard drive ,ect you may need a 650 watt power supply to run your system with the new card . ther are alot of power supply calulators on the internet just google pc power supplies
Mar 22, 2010 | BFG Technologies NVIDIA GeForce 9800 GT,, ...
Monitor not working with Geforce 9800 GT
The resolution is set too high for your monitor and you have to throttle it down to a lower number.
Apr 09, 2017 | Dell E151FPp 15" Flat Panel LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Acer Monitor will not function
Monitor is getting hot and cutting off. Try on another computer. Try another video card. If it does the same thing then it is BAD
May 24, 2008 | Gateway FPD2275W LCD Monitor
Polyview v396
Check the signal, is the monitor digital or analog, if your video card has a DVI conenctor, then the monitor should be DVI, so it needs to be set to Digital, If your monitor came with a CD, check to see if it has drivers that need to be installed
Feb 23, 2008 | Gateway FPD2275W LCD Monitor
Can't use DVI with monitor
You have 3 ports on your graphics card(VGA - 15 pin D-Sub x 1, DVI x 1, and S-Video x 1)Now if you want to use DVI just connect the DVI port to your monitor thats all..
Enjoy!
Oct 19, 2007 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
238 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
