Question about Lite On LITE-ON SOHC-5236V COMBO BK OEM (SOHC5236VBKOEM) Burner
Not working They dont even show up in "my computer" only floppy disk "A"
  • Anonymous Oct 14, 2008
    my lite-on sohc-5236v not record
  • 55 Answers
Did this just start recently?
Has it ever worked or are you just installing the drives?
Try doing a System Restore.
Start -> Accessories -> System Tools -> System Restore.
Back to the day before that it worked.
If this doesn't work, reseat the wires on the back of the drive.
(Or if they are new, return them to the store)
Posted on Mar 14, 2008
SOURCE:
My TEAC FD-05PUB is recognized by my computer. However, it will not open a floppy disk. It says the disk needs to be formatted (even thought the disk works fine on other computers with the same operating...
Try a brand new disk put something on it and go from there the disk you may be using may be no good anymore. Try this first before getting another replacement disk I would stop using these floppy and go to a USB Stick for storage purposes since they are going obsolete. Just a suggestion! That would solve your problem using floppies for storage besides they do not hold much information compared to todays storage devices. John
Jan 15, 2011 | Teac FD-05PUB External Floppy Drive
I have an external Diablo Tek usb floppy drive connected to my windows 7 premium computer. I hae copied files onto 3.5 disks using windows xp but when i try to copy them onto my windows 7 computer it will...
Can you copy them to another computer? More than likely, they actually are corrupt. The thing that made floppy disks unreliable long term is that they are subject to magnetic fields. Any magnetic field will corrupt the data stored on them. And electrical current produces magnetic fields. So, if you stored the disks near any electricity, they have become corrupt. In a handbag with a cellphone, on top of a computer or monitor, etc. ...you get the idea. They will last forever if stored properly...but most poeple don't. I have some 10 years old (and I don't even have a drive for them anymore) and I not too long ago pulled my resume off one of them..but if not handled exacly right, they crash. Let me know if you think this is your problem, or if you are certain you stored them correctly and really think it is something else we'll look deeper.
Jun 14, 2010 | Diablotek MOVING STAR USBFL-BK External...
Bought a new USB external floppy drive. Copied a
You may have a virus causing this...OR your computer USB MIGHT not be putting out the required 1/2 amp current. That you can fix by using a powered USB hub.
Dec 09, 2009 | Memorex Computers & Internet
I am now unable to access a floppy disk that I had been able to access for years. I now get an error message that tells me the disk has no ID address mark. How do I fix this?
Try changing the stting switch on the disk. I think it is for formatting or something like that. Try moving it to the opposite direction and then put it in your computer again ;) Good Luck
Nov 12, 2009 | Teac Floppy Drive 235HF Internal Floppy...
I recently bought a WD external hard drive my book essential1tb. I connected it to the computer using a usb. It shows up under My computer as G drive (My Book). Now, I was going to do my first backup of...
hey when you use the back up on the accessories, it pertains to backup everything that attached to your computer, the harddisk, c: an d: if you have a partion, and a: since your cd drive is reading cd that can be remove you dont have to back up that, and also you g drive cause you can remove it, the computer is set to back up only those drive, the floppy, and hardisk.
Nov 02, 2009 | Computers & Internet
Windows Vista shuts down when trying to access floppy drive
floppies are very much vulnerable to viruses. there might be an issue with the computer getting affected. i strongly recommend that you run a antivirus program before proceeding further. good luck!
Oct 14, 2009 | Dell Inspiron 530s Desktop Computer...
Ican't get a self installed floppy disk drive to work with Vista.
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Sep 25, 2009 | Teac Floppy Drive 235HF Internal Floppy...
Locked out of laptop
Start your laptop
type (administrator) as the user that is going to loggin them hit enter
if it need a password them
try
Offline NT Password & Registry Editor, Bootdisk / CDdownload here and burn it(bootable cd)
  1. Get the machine to boot from CD (or floppy)
  2. Floppy version need to swap floppy to load drivers.
  3. Load drivers (usually automatic, but possible to run manual select)
  4. Disk select, tell which disk contains the Windows system. Optionally you will have to load drivers.
  5. PATH select, where on the disk is the system?
  6. File select, which parts of registry to load, based on what you want to do.
  7. Password reset or other registry edit.
  8. Write back to disk (you will be asked)
Jan 11, 2009 | Microsoft Windows XP Professional With...
Problem with disk drive A:
First, you should try to keep the floppy drive. If you can find one, I highly recommend getting the floppy drive cleaner diskette. They're hard to find now, but it's worth it if you want to continue to use your floppy drives. If cleaning it doesn't resolve the issue, next item to try is replacement of the floppy drive. You can borrow a floppy drive from someone, plug it in and test to side if it fixes the problem, if not, then it's either a motherboard issue (which I doubt) or a software/windows XP problem (more likely of the two). In which case I would recommend reinstalling windows XP to see if it fixes the problem before shopping for a new motherboard or a new computer.
Good luck
Jun 29, 2008 | Dell Dimension 2350 PC Desktop
Lite On LITE-ON SOHC-5236V COMBO BK OEM (SOHC5236VBKOEM) Burner Logo
46 people viewed this question
Top Lite On Computers & Internet Experts
Pierre Laplante
Ekse
Damen Wong
Damen Wong
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
