Question about Garmin nuvi 350 GPS Receiver
Broken glass I bought a lamp that has small glass rectangles that fit into a metal wall. One of the corners of the glass broke off -it looks like it would be easy to reattach....what would hold it?
    Scholar:
  • 174 Answers
Not a GPS....I think
Posted on Jul 23, 2008
Bought 3 metal floor hurricane candle holders for our entryway ($220 each). Blind dog knocked one down and broke glass. Pier ! says they don't have replacement glass holder. Any ideas on where I can find...
These are specially made with to suit the particular requirement and there is no way but to get this replacement from the manufacturer. the other way out is to use the two remaining ones on either sides for a brighter light and use 10" pipes of PVC or transparent tubings to give a special shade. Check this out with the availability at a plumbing store. You can cut portions on the opaque shade and use acrylic pieces to be stuck within to give an art look.
Sep 23, 2013 | Pier 1 Imports Brown Pierced Metal Floor...
What kind of extension cord fits it?
The machine probably uses a plug like the ones used on computers. It is a smaller plug, like a rectangle with two of the corners tapered. A regular extension cord will not work. Take it back, and look for a power cord for a computer. Take a picture of the plug on the machine you are trying to use before you go to the store. The clerk should be able to help you find the right cord.
Nov 15, 2012 | Staples ID Armor SH2836ID2836 Shredder
Replace rt side (psg) front headlaight assembly, for a 97 cadilac deville.
pull upward on black cover above headlamp assy. (marked pull here for headlamp service) you will then see on the front side a large bolt above the lamp assembly that holds it to the front of the car. it is a 10MM socket you will then need to remove a similar bolt on the top and bottom on the center front of the car where the assembly bolts up to the sheet metal. on the corner near the cornering lamp is a star shaped head bolt. (looks like star of david) you will need another small metric socket to remove this. this will free up the cornering lamp from the headlamp assembly. gently pull forward and away from headlamp assembly. remove both light pig tails by gently twisting on pigtails. you will then see 2 nuts which are also 10mm remove these and gently pull forward on entire headlamp assembly. you will need needle nose pliers to compress the head of plastic retaining tabs on headlight and signal light pig tails where they are held into the headlamp assembly. gently twist hi-low beam sockets free of the headlamp assembly then do like wise with the signal lamps. to install reverse procedure as above. note: the side with the cornering lamp has a tab that must fit back into tab-hole in front sheet metal of the front fender.
Dec 18, 2010 | 1997 Cadillac DeVille
Changing the mirror
just make sure it is lined up and no other pieces broken
Jul 18, 2009 | 2003 Kia Sedona
1998 Mercury Villager front park light replacement
You remove the screw located at top near the corner of headlamp then gently pry the park lamp from the fender.
Mar 05, 2009 | 1998 Mercury Villager
Headlight assembly
Pull upward on black cover above headlamp assy. (marked pull here for headlamp service) you will then see on the front side a large bolt above the lamp assembly that holds it to the front of the car. it is a 10MM socket you will then need to remove a similar bolt on the top and bottom on the center front of the car where the assembly bolts up to the sheet metal. on the corner near the cornering lamp is a star shaped head bolt. (looks like star of david) you will need another small metric socket to remove this. this will free up the cornering lamp from the headlamp assembly. gently pull forward and away from headlamp assembly. remove both light pig tails by gently twisting on pigtails. you will then see 2 nuts which are also 10mm remove these and gently pull forward on entire headlamp assembly. you will need needle nose pliers to compress the head of plastic retaining tabs on headlight and signal light pig tails where they are held into the headlamp assembly. gently twist hi-low beam sockets free of the headlamp assembly then do like wise with the signal lamps. to install reverse procedure as above. note: the side with the cornering lamp has a tab that must fit back into tab-hole in front sheet metal of the front fender
Dec 15, 2008 | 2001 Cadillac DeVille
How do i remove and replace the driver's side mirror?
If the metal pivot arm is not broken you can just replace the glass and plastic housing. To remove the glass you tilt the glass down towards the floor and use a wide plastic or wood bladed object to prise from behind, the glass should pop off from its clips. Remember to catch it if its not damaged. To remove the housing once the glass is out you need to look underneath the mirror unit, there you will find a small plastic bung, gently prise it out and then use a long small flat bladed screwdriver straight up inside the hole and lever towards the front of the car whilst lifting straight up on the plastic housing, this should then lift off. To replace just slot the new housing on and click into place then fit the glass back, remember to connect the wires first if it is a heated glass.
If the metal pivot arm is broken then you will find the remaining screws behind the plastic trim inside the vehicle.
Oct 26, 2008 | 1998 Volkswagen Beetle
Replace passenger side power mirror clearance lamp (bulb only).
If you are facing the passenger side mirror adjust the top (large) mirror so that it is turning in towards the truck as far as it will go. Then look behind the mirror in the bottom righthand corner (outside bottom corner) and you will see a silver metal clip. Take a straight head screw driver and push on that clip and the lens will pop out. Then you simply unscrew the bulb holder from the lens and replace your bulb. Good luck!
Oct 16, 2008 | 2008 Ford F-350
Changing light bulb in a 25 year old freezer
Whatever you do, you MUST unplug the freezer before attempting any repairs... there will not be any release buttons, nor any special installations for water safety... also, take care to avoid cutting yourself on the broken glass..
1) did the whole light bulb glass And internals come out, or is the internal part of the bulb still present?
2) verify that the light bulb is really a screw-in appliance bulb -- look into the center of the broken bulb and see if the metal base has internal ridges -- or if the metal base is smooth on the inside...
3)  if a screw-in appliance bulb:  3a)  if the whole light bulb glass AND internals came out, you will have to probably look very close inside the socket to determine the wall of light bulb base... it should be very thin and flexible and very unlikely you can unscrew it directly -- I've had to take needle-nosed pliers and gently bend and twist until the bulb base came out...
3b)  if part of the glass remains as well as the internal stem, I have heard that one could cut a potato in half and then push the internal part of the potato onto the broken end of the bulb and gently unscrew the bulb by twisting the potato... never tried this so I don't know if it will work -- if the internal stem is still intact, I'd use my fingers and try to gently turn it to unscrew the bulb
4) if it has smooth inside wall -- this is probably a bulb with small exterior pins -- the base should be a little more thicker than the screw-in type, so you should be able to push the bulb base in -- a little give in the spring holding it in -- if you feel this give, then turn carefully counterclockwise and it should pop out...
Again, turn off all electrical power to the freezer, Pull the Plug before attempting any repairs... remove all glass and handle with care...
Jul 25, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Garmin nuvi 350 GPS Receiver Logo
46 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
