Hotpoint ultima wma66
Hotpoint wma66 is starting cycle, drawing in water, doing a couple of fast spins then drains the water and display turns to "on". Won't go any further, any ideas?
  • GAJ9 Jun 08, 2008
    Same problem. Considering whether worth having fixed or spend money on a new Miele with a 10 year parts/labour guarantee
  • 16 Answers
Sounds like the PCB is Freaking out. All you can do is Check all the connections between the Main board and Display board and if you still have the problem - then i'm afraid it is probably the Main Board gone Faulty.
Posted on Mar 16, 2008
SOURCE:
Control Module problem?
It sounds like the pump or drain hose is blocked by something, and if the water does not drain away it will not spin properly.
The last resort would be the control module which is about one hundred and fifteen pounds, so check everything else first.
Jun 13, 2014 | Hotpoint WMA66 Front Load Washer
I have a Hotpoint Ultima 1200 - WM75. At the end
Check the filter and the actual pump itself for blockage.unless you have already done so, also pump itself could be faulty.
Mar 29, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima keeps displaying an F10 fault and doesnt spin correctly. However, if I then switch it to a rinse and spin cycle it seems to spin OK.
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Jan 17, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960 machine does not drain the water
Your drain pump is out. Usually attached to your motor and operates when the drain cycle is engaged. It's usally a 20 dollar piece. good luck.
Apr 17, 2009 | Hotpoint Ultima WF860 Front Load Washer
Just plumed in my hotpoint ultima it has done a
when you start the cycle the water will disperse. but check the fillters at the bottom of the dishwasher and make sure the drain pipe end is not crushed if you are enptying into the kitchen sink drain make sure the pipe is not kinked back on its self. try and get it as strait as you can.
Mar 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint ultima super silent displays 'test' but dnt run cycle
its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
Jan 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WMA66. It goes thru the wash cycle but doesn't drain to go on to rinse/spin. It continues to turn and when the timer run's out it just stop's and is still full of water. Any ideas??
This must be a European model. If it wil not spin and water will not go out it has to be something stuck in the drain pump. You shoud have access through the bottom panel.If you have one remove it you should see drain pump.
Jul 24, 2008 | Washing Machines
Hotpoint ultima wt741
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Washing Machines Logo
164 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
