Question about iLO (2 GB) MP3 Player
Won't read music
The MP3 ilo will not read the music. It will have a gig of music on there and it still said no files. I've tried formatting it. I checked the wires and there fine. Whats wrong
  • 8,596 Answers
Check and make sure that the format you are trying to play is compatible with the player. For instance, iTunes files won't work with this player.
Also, you could be trying to load DRM-protected files from a service like Bearshare. Yuur screen will tell you the files are transferring, but they are really not transferring b/c they have DRM protection. There is not currently a free way that I know of to remove this DRM-encryption, although you can probably buy download rights from your music service.
Unfortunately, the ILo site is down, so their is no way to get a firmware upgrade in case this model is another victim of the Windows Media Player upgrade - WMP 11 messed up a lot of mp3 players regardless of manufacturer.
Posted on Mar 15, 2008
SOURCE:
What to with unsupported media file message in mp3 player
then you have loaded the mp3 player with some files that it can't read such as a .wma .acc check and make sure what your mp3 player supports and then if necessary get a converter to convert the music to .mp3 format
Nov 25, 2009 | iLO (2 GB) MP3 Player
I have problems with format erros from limewire
Maybe you can check at the end of the music file and make sure they are no other extension. Also, it could be that the mp3 files are encoded into a higher or lower codec which your device cant read. Check properly the files you download.
Aug 18, 2009 | iLO MP3 Player
Everytime I try to load music it says files corrupted
I think the music files you are trying to load is not in a format playerble by your device or player. If you are trying to load music to your MP3 player, it must be in either MP3 or WMA format. If it is a media player like WMP or Realplayer, the file must be supported by he application.
Dec 13, 2008 | iLO Audio Players & Recorders
ILO mp3 PLAYERS
what gigs does ur mp3 has??...maybe its low u download many tunes on it??...or u will need to upgrade it
Jun 14, 2008 | iLO (2 GB) MP3 Player
How to get downloads in order
plug your mp3 into your computer then open up my computer. [start, my computer, it will read as a removeable drive open it up and there should be your files in there. you will be able to organize your data like any other folder. let me know if it works. good luck
Feb 17, 2008 | iLO (2 GB) MP3 Player
Not recognizing music on SD card
Not sure if you have found the solution to your mp3/SD-card problem, it has been almost a month. Obviously I had the same problem. That's how I found your question. What I did was re-format both the mp3 and SD, then loaded the SD card first and sofar so good.
Jan 10, 2008 | iLO (2 GB) MP3 Player
Innovage mp3 wma 1gb format error
plug in your iLO and go to "start" at the bottom of your screen and go to My Computer then go to Removable Disk and right click. Then go to format
Dec 20, 2007 | iLO (2 GB) MP3 Player
Some music won't play
if the songs came from Limewire, they probably have hex code in the id3 tag comment lines - remove all of these tags
Nov 19, 2007 | iLO (2 GB) MP3 Player
Memory issue.
try to find in my computer and open music file and click and drag music to the folder and see if it takes. May have to delete driver and reinstall.
Sep 08, 2007 | iLO (2 GB) MP3 Player
Ilo mp3 player issue
Your ilo should've come with a disc. That disc should install windows media for you. You can't put music onto it without windows media.
May 05, 2007 | iLO MP3 Player
iLO (2 GB) MP3 Player Logo
59 people viewed this question
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
