Question about HP Compaq nx5000 Notebook
Startup trouble It does not matter if the battery is installed or not, as soon as I plug in the power plug, the processor fan starts spinning, before I even touch the start button, it runs for a few sec,stops,runs again,stops and so on, and nothing else happens.
Could you please give some more details about how i would go about doing that, as i'm a bit of a beginner.
Posted on Apr 09, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 171 Answers
Fix another ram and check, otherwise it will be the motherboard problem , one more option is remove the harddisk and check
Posted on Mar 15, 2008
What would cause my aspire 5630 to shut down sporadically?
Shut down sporadically, caused by rising temperatures on the processor (processor overheat). Processor overheat, caused by damage to the processor fan. Processor fan function to reduce the processor temperature.
Possibilities and solutions
1. The possibility of sluggish processor fan. Processor fan spins, with a low speed, so it can not reduce the processor temperature.
Solution: clean the processor fan with a vacuum cleaner, or replace the processor fan.
2. The possibility of fan processor die.
Solution: replace the processor fan.
The characteristics of damage to the processor fan
After the laptop is turned off (more than 1 hour), the laptop can turn on and survive + - 30 minutes. In the period of + - 30 minutes, the laptop died suddenly, because the processor temperature exceeds safe limits (shut down temperature).
How to check
Laptop is turned off (more than 1 hour), then turn on. Download and install software to check the processor temperature. Ex. Real Temp 3.60. See the change in temperature. If the temperature continues to rise, it can certainly cause damage to the processor fan.
- Normal temperature, when first turned on + - 38oC
- Normal temperature, after turn on for hours 40oC - 45oC
- Temperature overheat processor, when first turned on 60oC - 65oC
Nov 18, 2011 | Acer Computers & Internet
Laptop shuts down prox 1 minute into startup.
Did you check if the fan is working, and temperature is ok, you need to use a software
Apr 04, 2008 | Toshiba Satellite A105 Notebook
Hi! I have a laptop repair Satellite A305D-s6848. I turn the laptop fan spins, no display, it can not turn off power button. Can there be a reason for the bios? Please help Hdd drive is removed,...
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 20, 2011 | Toshiba Satellite A305D-S6848 Notebook
Slow start up and shut down
You didn't mention what version of Windows (Is it Windows, or is it Linux / other?) that you are using. For laptops in particular, windows sometimes gets confused as to which power saving state that the laptop should be in.
Next time that windows is running, you should see an icon of either a battery, or of a power plug in the area next to the clock (lower right corner). If you LEFT click on this, there will be a list of various power schemes that are available. MAX BATTERY will reduce the processor speed the most, while ALWAYS ON turns off power saving altogether, and allows the laptop to run at full speed.
If your fan always seems to be on, or seems to be cycling on and off rapidly even though you are doing little with the computer, then you might need to have the fan and heatsink cleaned out (consult a computer shop). When the processor starts to run hot, the motherboard will begin to slow it down regardless of the power scheme.
You might also be looking at a program that is loading during startup (did you just happen to install Open Office by chance?) that also takes a while to unload while shutting down. Consider what you have recently installed, and check your startup menu (click start >> programs >> startup ) to see what is being loaded there.
Feb 13, 2011 | Dell Vostro 1510 Laptop
Computer shuts down on startup
Good morning! it is possible the heat temperature affected the start-up on/off condition, kindly check the CPU FAN if still in good working condition otherwise we have to replace it, then check the computer ventilation if still we need to install an exhaust fan 12v designed for computer. However, another case can be the wattage rating of your Power Supply (ex. 200W) which support the power requirements of all parts & devices of your computer especially during CD burning, if this is the case, I suggest to replace it with higher rating around 400W-500W. best regards
May 09, 2009 | Computers & Internet
Barebones troubleshooting
Lex -
I would first check your ram, make sure its the right type and rating for the motherboard. Although most systems will beep at post for a memory issue, sometimes reseating the memory alone can clear up a startup hang.
If the memory is seated okay, the right type and speed rating, try using a different video card in the system. Its possible that the system is starting up normally, but not being displayed.
If neither of those help, minimize the system. Plug in just the bare minimum needed for operation - Power supply, processor, heat sink & fan, a single memory stick, a single hard drive, video card(if its not integrated on the motherboard). Plug in a monitor and the power cord, then see if the system boots.
If all that still fails, verify that the CPU fan AND the Power Supply fan are spinning when power is on. If so, this points to either a bad memory stick(try another), bad processor(if available, try one at a slower or faster speed), or bad motherboard.
Hope this helps!
-thinstatic
Jun 13, 2008 | MSI MBOX KM4M-L (ms-6734bb-040) Barebone
Processor fan failure massage.
I supose the fan works, you then need to enter bios and disable cpu fan monitoring, if the fan doesnt spin connect it to another fan connector or a plain 4pin molex connector / might require a adapter.
Try to get into bios and disable cpu fan fail alarm, keep the temperature alarm on 80 or 70. so it will yell if it gets too hot.
Apr 17, 2008 | Intel Motherboard
Computer restart
yes the problem as you discussed was the processor's overheating. first, you need to open up the side cover of your casing then switch on check vissually if the fan of the processor is spinning if not then you need to replace this. and if this is spinning upon power on, the power supply will be checked its voltage.
Mar 25, 2008 | Computers & Internet
Compaq nx5000 startup trouble
Atleast you need a dummy battery on it,put the battery on it and check , one more way is remove the ram and fix
Mar 13, 2008 | HP Compaq nx5000 Notebook
HP Compaq nx5000 Notebook Logo
133 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
