Power Supply fuse blows HOT checks ok But does have a short somewhere.
  • 2 more comments
  • Ray Jones Mar 14, 2008
    Brand Symphonic Mfg. Funi Corp.Inc. Board#2642308 alt.#80211477 It has Toshiba Transistor for HOT# D2638
    This is not a projection tv it is a symphonic 27' picture tube model. Ray Jones
    Jamie867 Brand is Symphonic 27" Picture Tube type Board Sticker has two numbers top row is 2642308 bottom row is 80211477. Mfgr. Funi Corp. Inc. Model # WF27F4
  • Jaime Hernandez May 11, 2010
    Can you provide us with more info on brand, model and chassis number?
    The more info we have the better we can point you where to check.
Ray Jones
I posted the solution that you notified me about . I thought it might help someone else. I do thank you for your help Jamie867.
Posted on Mar 25, 2008
The problem was two IN5406 diodes in the switching power supply was blown and replacing these got the set up and running again thanks for your help.
Posted on Mar 21, 2008
  • 2,336 Answers
I look for an schematic diagram but i was unable to find one. I guess we can try to fix this one the old fashion way without the schematic.
I would suggest to check the voltage regulator for a shorted condition and all the diodes and capacitors near it. If your horizontal transistor is good the short is somewhere the power supply but you can also check any other part that has the B+ 130VDC.
Let me know if you need more assistance.
Posted on Mar 15, 2008
I have brake light and horn problem
you have a hot short between the brake light or horn wire. It is touching a ground somewhere. Trace out both wires to ground and see if they are not touching somewhere. It may also be a short in the fuse box? May be brake pedal sensor is shorting out. Or the horn has a short to ground.
Dec 13, 2014 | 2007 Yamaha YZF-R1
IT KEEPS BLOWING CAR FUSES
Power inverters can do this if they are internally shorted or they are being over loaded. If you are just using it to charge a phone or a computer it should not be over loaded. Now if you are charging a computer and running a small cooler at the same time, that may be real close to max which may blow a fuse. Have you tried hooking it straight to the battery to see if it will run what ever you are running. It has it's own fuse so if it has an internal short it will blow that fuse. It if works hooked to the battery and is just blowing the cig lighter or acc. fuse it can be a weak socket. If the socket is hot it may have a loose wire on the back side causing low voltage which can blow a fuse. So hook it to the battery direct, if it works ok there, reconnect it to your acc port and if it is getting hot it may be the weak socket. If it will not run hooked to the battery, it has an internal short and it would be better to buy new than try and fix. Sorry.
Mar 22, 2011 | Vector VEC 024 400-Watt Power Inverter...
Keeps on blowing fuse
Hello
If fuse blows off repetedly, it shows that there is a direct short inside the power supply section. You just check the mains rectifier diodes for short. iIf a rectifier stack is used desolder it out and check for short. In some sansui sets, ther is a metal oxide variste connected across the supply line inside directly. It is for line spike suppression and an overvoltage protection. If any of the above appears on the power line, the varistor will get shorted, and the fuse will go out, to prevent further damage to the circuits. Check that varistor for short. Check the resistance across main filter capacitor for any direct short. If it seems shorted, check the switching transistor for collectror to emitter leak, Resolder it out and check. These are the main reasons for blowing fuse. If the switching transistor has got leaked, you must check the entire SMPS control section, especially in case of used zener diodes, before replaceing a new transistor. OK.
If you wants anu further assistance, inform me through Fixya. Ok.
Nov 05, 2010 | SansuiS2746 TV
I have a KP-46WT510 and have replaced both STK chips and 1 fuse on the power supply board. Under the heat sink there is another fuse burnt. The value of the fuse needed is 3.15 A. I put in a 3 A fuse and...
I have worked on about 5500 projectors in the past 10 years.
There is a dead short already somewhere so you cant blow anything else up if its a fast blow fuse.
Disconnect the Convergence Amp from the pwr sply then power it up for a few seconds with your 4amp fuse. Does the fuse still blow? If so, check the HOT transistor. (3 pin chip againts the largest heat sink)
Good luck
Dec 30, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Blow fuse
If the TV keeps blowing fuses, there most be a short somewhere. Most likely the power supply board itself somewhere. But take it to a repair shop to find out for sure. The sad part maybe that you'll have to pay over $100 for someone to look at it.
Feb 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Keeps blowing fuse
It has a short circuit somewhere...
Not sure if this is a CRT, LCD or Plasma TV but the two common causes of shorts for CRT's are the Horizontal Output Transistor (HOT) and/or the Flyback Transformer (Could be both). As a general rule if the flyback has visible cracks in the case they should be replaced. It is also a good idea to replace the HOT if you're replacing the flyback as it could be weakened and may not last much longer itself.
Other areas to check for all types would be any Diodes in the Power Supply Circuit. If a diode is open it can cause the fuse to blow. Note that a diode itself will not short, but an open diode can cause a fuse to blow.
Mar 11, 2008 | Panasonic CT-32HL43 32" TV
ZENITH BLOW`S FUSE
you have a direct shot in the power supply check the rectifier diodes (4 of them) or check for shorts to ground other components. check the HOT for short between emmiter and collector, and base and collector.
Feb 02, 2008 | Televison & Video
Its actually a 13GP244
you need to check the power supply area. usually when a fuse blows, that means the bridge rectifier is blown or the ic in the power supply area is blow too or both are blown.check there..good luck
Apr 04, 2007 | GE 13GP243 TV
My tv power does not come on
This set uses a switching power supply. Usually when there is a short on the output side of the switching transformer the supply will just shut down and refuse to operate but normally will not blow a fuse. If the fuse blows suspect a problem with something shorted on the input side of the switching transformer such as I801 regulator IC, diode bridge D801,or other shorted component. Perhaps someone else could tell both of us any other part that could cause the regulator to blow and should also be replaced to prevent regulator failure in the future.
Jun 23, 2006 | Sylvania 6427TE 27" TV
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
