Question about Gateway 507GR PC Desktop
San disk memory stick pro duo
Can't get it to download pictures on my computer.... Can anyone help me ? I even bought a card reader from Best Buy and could't get it to work either... Please help if you [email protected]
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 194 Answers
What pictures download and where you are downloading from post the problem clearly . then ask for solution
Posted on Mar 15, 2008
SOURCE:
Sony memory stick duo pro 1gb is using for Sony handycam is suddenly started giving error message like reinsert memory stick. I have important pictures and video in it, now i need to recovery them. Do...
Hi Devika,
Buy a card reader that can read your memory card and connect to the computer. (Less than $8 in Sri Lanka). Connect it to PC and insert the card to the card reader.
Download Recuva and run it. select the memory card. Try to recover the files.
Best of Luck!
Sep 21, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
My memory stick pro duo is not read when I stick it into my memory card slot on my laptop. I do not have the USB cable to hook it in otherwise, is there a way to upload my pictures?
you can buy a All in one USB Card reader/Writer and then insert the memory stick pro duo card in it and plug in the USB Card reader/ writer
to the USB port on your laptop and you should find the same listed under removable devices under my computer. good luck
Sep 13, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
How Can I read my Memory Stick Pro Duo MARK 2 on my Computer? MY problem is I cannot read my Memory Stick Pro Duo Mark 2 on my computer but my computer is showing another Removable Disk(F:),which is my...
    • 1 Visit the Sony Support site (see Resources) and download the Sony memory card software. You will need to specify your operating system. Save the file to your desktop.
    • 2 Double-click the downloaded file to launch the installer.
    • 3 Follow the onscreen instructions to install the Sony memory card software. Restart the computer after completion. Once the computer starts back up, it will recognize the Memory Stick Pro Duo when inserted into the computer's memory card reader. You can browse the files using Windows Explorer or the installed x-Pict Story software.
May 31, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
Not able to view pictures from sandisk memory stick pro duo on my laptop when connected using card reader or by using the USB cable of the digi cam directly.
Don't know about cam (was there a software disk to install?).
As far as the reader goes you reader must be compatible with both devices.
Hope this helps
Oct 26, 2010 | SanDisk 4GB Memory Stick PRO Duo Memory...
How do i download from a san disk memory stick pro duo - 512 MB? the stick itself is way too narrow and short. help?
Aluratek AUCR200 Card Reader
Please gave a vote, it will give me some satisfaction to know that am helping some one so I will keep on helping.
Thank you.
Mar 14, 2010 | SanDisk 2GB Memory Stick PRO Duo Memory...
Memory stick pro duo
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format stick pro duo
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 28, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
MY PROBLEM IS THAT MY LAPTOP HAS WINDOW VISTA SYSTEM AND I CANNOT LOAD MY PHOTOS FROM MY SONY CYBERSHOT DSC P73. I NEED THE PROGRAM OR WHAT I NEED TO DO?
To make things easier, you should buy a card reader. There are different types.
MS Pro Card Reader - Is ONLY for the sony memory cards
Multi Card Reader - Will read sD, xD, Ms Pro Duo, Ms Pro, Compact Flash, Smart Media, etc.
Sony has a new memory stick out called the memory stick pro duo. Your P73 does not take this. The P73 takes the Memory Stick Pro. Which is a longer stick. You can go out to best buy or ritz camera and buy a card reader (Memory Stick Pro) and stick your memory card into the card reader and stick that into your USB port on your computer. Since it is USB, this will require NO SOFTWARE.
Your camera came out in 2004. Vista did not come out until early 2007. A lot of software does not work with vista.
Mar 29, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
CAN I UPLOAD PICS FROM MY SONY CYBERSHOT W55 USING A SANDISK??
what do you mean nothing happens???
the memory stick pro duo should fit right into the sony cybershot....
if your struggling to load your photos onto your computer buy a universal memory card reader!
you should try and use a memory stick in a camera that needs an sd though!
Oct 16, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Memory card error
did you already formated your memort stick? try to remove your memory card from your camcorder and insert it again. look for the settings on your camcorder. it might cause the problem. hope that helps!
CHARCOIS
Aug 17, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
San Disk Memory Stick Pro Duo 2.0 GB
Is its reading from camera are you watching your pictures from camera if yes what the error is showing when you are opening and it which company memory stick and what operating system it support give me the memory stick details
Mar 15, 2008 | Gateway 507GR PC Desktop
Open Questions:
See all Gateway 507GR PC Desktop Questions
Gateway 507GR PC Desktop Logo
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
