Question about Tappan 30IN ELEC IGNa Oven
Wall Oven won't work
Please note: I own a
Tappan Micro Wall Oven Model 57-2709-10/07 Serial Number NF33106667
It would not accept this as a valid product!
After baking chicken with a temperature change from 425 degrees F to 350 degrees F, I have been unable to use the oven. When I push any of the buttons except "cancel" the display says "OFF". The microwave part works well, the clock works except I can't set it. Turning off the breaker box to reset it twice did not help.
I have a circa 1963 tappan wall double oven. The timer on the clock needed to be turned counter clockwise one full revolution and then the top oven would come on. It wouldn't before
Posted on Sep 03, 2008
I tried randomly pushing 2 buttons at a time, and when I pushed "Timer Off/On" and "Cancel" together it unlocked and is now working fine. The following day it beeped a lot for an hour or so (must have been catching up on previous pushes) but now is back to normal.
Posted on Mar 19, 2008
SOURCE:
Desperately searching for User Manual for Tappan Wall Oven Model 12-4990-00-04.
Hello Owner, thank you for your inquiry!
I understand that you need the use and care manual for your Tappan wall oven, 12-4990-00-04. If the model is older than ten years old manufacturers will not keep that information available. You might be able to perform a search for antique models online for any additional information. -Matt
Jan 11, 2016 | Frigidaire Ovens
Seal on Tappan wall oven came off, what to do?
Hey friend, I appreciate your post!
I understand that seal on your Tappan wall oven has come off. In order to provide you additional information regarding the seal I would need your model number and serial number. You can locate the serial tag (which has your model number listed) on the front of the oven on the left side. With that information I could provide you additional assistance. I look forward to your response. -Matt
Aug 03, 2014 | Tappan Ovens
Manual for Tappan Wall oven
I just replaced my springs, the springs are the same as okeefe and merit
i have probably the same oven as you . Antiquegasstoves.com They have many pictures of all the springs there! mike summers
Apr 05, 2009 | Ovens
F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
please take the time to give this solution a fix ya rating.
clarkco
Feb 09, 2009 | Tappan Ovens
Problem with tappan wall mounted oven
yes, the problem is fixed thanks to repairclinic.com. those guys are awesome and there is no fee for their help. the repair parts are cheaper than anywhere else i've checked and the tech support is second to none.
Oct 11, 2008 | Ovens
Tappan Gas Range Pilot light went out.
throw the piece of **** out! nobody seems to know how to do this, and there is zero customer service or help available. there are problems like this all over the net with no answers.
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Doesn't work
Dear Trenneth,
I tried pushing combinations of two buttons simultaneously and mine unlocked. It was a Tappan Micro Wall oven so I don't know if it will work for you but...what do you have to lose?
Mar 19, 2008 | Ovens
Tappan 30IN ELEC IGNa Oven Logo
518 people viewed this question
Top Tappan Ovens Experts
Thomas F. Schneider
Marvin
Marvin
john h
Are you a Tappan Oven Expert? Answer questions, earn points and help others
