Question about Acer Aspire 3610 Notebook
Battery my battery has died so i am useing the ac adapter will this harm any work on the computer and what is the best battery to buy for the 3610
    Scholar:
  • 105 Answers
No problem in using the correct AC adaptor without a battery - in fact if the laptop is used mostly on AC power I recommend removing the battery but fully charging it and discharging it once a month - the battery will last much longer when cycled rather than being constantly chaging. For replacement just type acer aspire 3610 battery in ebay:
http://computers.search.ebay.co.uk/aspire-3610_Batteries_W0QQa10244ZQ2d24QQa14ZQ2d24QQalistZa14Q2ca10244QQcatrefZC6QQcoactionZcompareQQcoentrypageZsearchQQcopagenumZ1QQdfspZ1QQfposZE5Q208RSQQfromZR2QQfsooZ1QQfsopZ1QQftrtZ1QQftrvZ1QQga10244Z10425QQgcsZ2372QQpf_queryZaspireQ203610QQpfidZ3477QQpfmodeZ1QQreqtypeZ2QQsabfmtsZ1QQsacatZ14295QQsadisZ200QQsargnZQ2d1QQsaslcZ3QQsbrftogZ1QQsofocusZbs
and you have a choice of new and second user - local or Asian.
Posted on Mar 14, 2008
  • 47 Answers
I can't forsee a problem but I'd backup my system and buy a backup battery if it were my system.
There are so many computer parts/battery stores online these days but I can't recommend any particular one. Shop around and do some price comparisons. I've had luck buying batteries on ebay, but use caution there or you might end up buying a battery that's deader than yours.
Cheers,
Rick
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Hi forum, I have been using Compaq N610c notebook and was working fine but was not power ON . on AC adapter but it was working on Battery. From last day, the battery become zero showing battery indicator...
It's possible that the AC adapter "died", and then your computer ran on battery-power until the battery went to 0%.
Or, the socket on the laptop where the AC adapter connects could have broken, or become disconnected from the motherboard, such that the power from the AC adapter was not being accepted, meaning that your computer was running on battery-power.
Take the AC adapter and the computer to a qualified technician, who can test that the AC adapter is working fine, and can disassemble the laptop, to inspect that socket where it connects.
Mar 03, 2010 | Compaq Evo N610C Notebook
New AC Adapter Will Not Charge Battery/Operate Computer
Most probably static electricity killed some circuitry inside your laptop.
Nov 12, 2009 | Acer Aspire 3610 Notebook
I have an Acer Aspire 3610 notebook. It wont charge
How old is your battery? When you use your laptop, do you run it on just the battery or do you use your a/c adapter and battery? If you're going to use your laptop for an extended period of time, it's recommended to remove the battery and run off of a/c power alone. This helps to extend the life of your battery. Over time, using both a/c and battery will cause your battery to charge/discharge, which dramatically shortens the life of the battery.
You may simply have a dead battery.
Another alternative is that you have a bad power unit, which is what the a/c adapter plugs into on your laptop. My guess is that you most likely have a dead battery.
Oct 07, 2009 | Acer Aspire 3610 Notebook
Dell xps m1210 won't power up with new battery. Check notes.
If it is working fine with a fresh battery then it is not a motherboard problem. It is either a bad ac adapter jack on the motherboard or the actual ac adapter cord is not working. Try cables2go.com as they have replacement ac adapters for almost everything under the sun. Hope this helps.
Jul 10, 2009 | Computers & Internet
Hp compaq nx7400 - battery died and power cord will not turn comp
Some laptops will not power up with a completely discharged or faulty battery. Remove the battery from the laptop, plug in the power cord and try to boot the system. If the system boots, your battery needs to be replaced. Replace your battery as soon as you can, it's not a good idea to run the laptop for extended periods with an open battery bay.
May 07, 2009 | HP Compaq Presario V2000 Notebook
Wont power-up with AC adapters, with or without Battery!
the notebook cannot be charged without the charger and further more if it is not working properly ,try get a new one and it will work.i also recommend that you show it to a technician .
Dec 24, 2008 | MSI MS-1022 Notebook
Boot problems with Acer Aspire 3610
do you have power ? if no, check your power outlet and ac adapter first, if both of them are ok, it could be your motherboard.
if you have power but no display, this is called no post.
reseat your memory. if still not working, use 1 memory and try to put it in different ram slot. and if this is still not working, your motherboard is bad
Jul 26, 2008 | Acer Aspire 3610 Notebook
Aspire 3610
Your Batterys Dying/Dead/Surrendered/Knackered/ et,c.
Use your Laptop On A/C Mains power. buy a new battery.
*******FIXYA********
Thanks mike @ compurepair.
Feb 28, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 3610 Notebook Logo
101 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
