Question about Hotpoint Ultima WF860 Front Load Washer
Shorting fault Hotpoint first edition 1000
My Hotpoint waqshing machine trips the electrics after just filling,have checked the motor and it seems ok what else could it be ??
  • Anonymous Jul 19, 2008
    Same problem - it has happened twice before and it's the eating element. If you live in a hard water area the element builds up limescale and this stuffs up the heating element. You will need to replace it and I suggest you put a water softener on your feed to the washing machne. Also, don't overdo the washing powder - many are now concentrate yet pople still put loads in.
  • 105 Answers
Faulty heating element
Posted on Mar 15, 2008
Posted on Jul 19, 2008
SOURCE:
Hotpoint washing machine HV8B593 trips RCD after a few secs without start button being pressed
If it trips the RCD then you have an electrical fault. Washing machine can do this once they are a bit old, or if they have had a water leak. The water gets into the electrical equipment and causes a fault that trips the RCD. If you have a circuit without an RCD try that. If it still trips, then the fault is serious and you will need to get it repaired. You can also try putting the washing machine into a warm place for a few days to see if it will dry everything out. Sometimes this will cure a fault if it is due to dampness.
Sep 01, 2018 | Hotpoint Washing Machines
Hotpoint first edition 1000 washer keeps trippin the electrics
Obviously a dead short somewhere. The only way to locate what it is , is with a multimeter. or by trial and error. Disconnecting 1 component at a time until it stops tripping the breaker. Not a very professional way but it works. I would start with the heater element first and then the motor. Make sure any wires that are disconnected are not touching anything and make sure its unplugged when you go taking wires off. Be safe , if you are not sure, get a Tech in.
Jan 05, 2015 | Washing Machines
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
Dishwasher fills with water but when it should start washing it sounds like the pump trys to start and trips out, this happens over and over while still filling. any ideas?
Hiya,
without the make and model number its hard to tell exactly what the fault is,
Generally this is caused by a siezed motor, could be something got into the impellar or worn out.
When you say trips out, do you mean electrics trip?
If so, you have probably had a leak in the base of the appliance and shorted the motor.
Hope this helps.
Regards
Sussex engineer...
Please rate my help.
Oct 22, 2009 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Aug 26, 2009 | Hotpoint Washing Machines
Hotpoint WM51 Washing Machine keeps tripping the electric
Ok that rules out the heating element. There are a number of possible causes so bear with me while i go through them.
Can you open the door? If so leave it open then turn on the machine. Does it trip?
Jan 23, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint FDW60 Flashing lights 3 and 5
Is it possible that water has gotten inside the controls that could have caused the flashing lights? Kind of like spilling water on a calculator, everything seems to go haywire.
Jan 11, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Faulty Hotpoint WMA76 washing machine
it may be 1) a connection loose at the motor 2) motor brushes are worn out 3) a pcb fault check in that order.
Feb 16, 2008 | Hotpoint First Edition WMA12 Front Load...
Hotpoint Aquarius 1000 WM62 motor problem?
hotpoint aquarius 1000 if motor is connected (plastic plug in socket) RCD earth trip trips in main board when washer is switched on, trips as soon as water starts to fill.
Oct 16, 2007 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
322 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
